usocazy
- May 11, 2013
- 292
- 45
- San Antonio, Texas
- 2004
- Hemi 5.7l
So I'm having some issues with my ABS module and sent it out for repair. The pictures show the male and female connectors of, what I think, are the source of my error codes:
41 - Right Front Isolation Solenoid Open
45 - Left Front Isolation Solenoid Open
51 - Rear Isolation Solenoid Open
52 - Rear Dump Solenoid Open
65 - Internal Main Relay Open
2 of the male connectors (left pic) are completely corroded off into the female portion (right pic) of the connector. Somehow moisture got into the connectors and ultimately deteriorated the connections.
I'm going to do my best to clean up the existing female connector and try to get out the male ends that are stuck inside. It appears from the photo that there is a silver connection that runs from right to left. On the far right side the silver portions are clean and clear - as you move to the left they get progressively worse. Hopefully that just cosmetic.
Another forum member recommended splicing in a used (but good working order) female connector but I have a couple of questions.
1. Are all 3rd Gen Rams 4 wheel ABS? Mine is according to my build sheet but I have seen mention of Rear Wheel Anti-Lock (RWAL) for some models.
2. How sensitive are the electronics associated with ABS? What do I need to be aware of if I elect to splice in a new connector? I have someone available to me that is very proficient at using a soldering gun.
I truly appreciate any feedback you can provide.
