Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Interior
Interior
Water on passenger side floor board
This is a discussion on Water on passenger side floor board within the Interior forums, part of the 2nd Gen : 1994 - 2002 category!
I have a very strange problem that not many people have had that I have talked to, water on the ...
Reply
Old 09-19-2016, 07:10 PM   #1 (permalink)
Ram Year: 1998
Engine: 5.9 360 V8 Magnum
Default Water on passenger side floor board
I have a very strange problem that not many people have had that I have talked to, water on the passenger side floor board. This is what I have found so far. I'm pretty sure it's not the A/C box because the puddle doesn't start at the top under the box but down on the floor by the chair mounting bolt. I have already check anyways to make sure the drain tube isn't clogged either just to be safe. I've pulled the carpet back and felt under it where it hits the firewall and it is dry as a bone there.
Some people have also said the third brake light could cause the problem but about a year ago I ordered LED taillights and the third brake light came with a new gasket. But I have siliconed around it too just to make sure. I'm also pretty sure that is not the problem either because the water doesn't come from the back and move up front, it starts by the the door in front of the chair by the mounting bolt closed to the door and spreads from there.
I've pretty much run out of ideas. I've gone around and siliconed up around the whole top of the door molding, around the back glass(which is a sliding one), siliconed up under the truck too everywhere where I thought water could get in. It only seems to do it after a heavy rain. I thought I had it fixed a couple months ago but yesterday we got a heavy rain and after I found the problem had returned. It got so soaked that it was dripping out of the pinch rail onto the ground. I pulled the plastic molding strip up today and got the shop vac and tried to suck up as much water as I could and let a fan sit on it.
If anyone has any ideas on what it could be, I'd greatly appreciated the help. This has been going on for only about a year and a half now but I've either checked or siliconed everything I thought it was and obviously it hasn't been successful.
Thanks in advance!!!
Sponsored Ad
Register to remove this ad.
CountryBoy1630 is offline   Reply With Quote
Old 09-19-2016, 09:05 PM   #2 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
Heater core. Very common actually
__________________
2001 Ram 1500 QCSB, 2" HBS level 285/70/17 Toyo OpenCountry AT2s, M1 2bbl, F&B 52x55mm TB, Pacesetter Longtube headers, 18" Magnaflow, M1 91 Octane canned tune by FlyinRyan, remote start, HS 1.7 RRs, Custom RetroFit 6500K HID
Old 09-19-2016, 09:06 PM   #3 (permalink)
dapepper9's Avatar
Ram Year: 2001
Engine: 5.9L V8
Default
Nvm just read the heavy rain part. Good chance of it being a certain vent hole. Cant remember much about it but dodge dude94 had a similar problem
__________________
Old 09-19-2016, 09:49 PM   #4 (permalink)
Ram Year: 1998
Default
I forgot to mention that it didn't smell like antifreeze. There must be a vent hole that I'm missing because I can't seem to locate it😂
Old 09-19-2016, 10:28 PM   #5 (permalink)
Ram Year: 1999
Engine: 318 5.2l
Default
Have someone run a water hose over your windshield while u sit in your truck and see if you can see where water is coming from. I done this last summer after I discovered my 3rd brake light was leaking to make sure I fixed it
Joe w. is offline   Reply With Quote
Old 09-20-2016, 03:13 PM   #6 (permalink)
fla crkr 1 ton's Avatar
Ram Year: 2001
Engine: 5.9 [360]
Default
My 98 had the same thing it was where the ac drain came thru the firewall i added a drain tube and sealed the hole also the radio antenna gromet sometimes leaks these are photos of my 01 the locations should be the same.
Radio antenna and ac drain line [with hose installed].
__________________
Redneck engineer'in beat ta fit paint ta match!!
1998 ram 3500 cummins dually
1966 plymouth barracuda 273 cid auto
2011 mustang v6 305 hp 6 speed manual
2006 volkswagon jetta 2.5
USAF Aircraft Mechanic 1979-1989
fla crkr 1 ton is offline   Reply With Quote
Old 09-22-2016, 07:48 AM   #7 (permalink)
Ram Year: 1998
Default
Thanks! I'll look today and see if that's my problem! I appreciate the input!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Driver side sits 3/4" lower than passenger side Upthewazzu Exterior 9 06-07-2015 02:09 PM
Hump in passenger floor board!!!! Bigskyguy81 Interior 14 08-10-2014 08:33 PM
leak water passenger side michelram General Discussions 10 07-30-2014 10:01 PM
Water leaking/draining water on passenger side.. DatacomGuy Tech Info 8 07-21-2014 12:35 AM
Passenger side of truck sits 1" higher than drivers side MaxinVegas General Discussions 6 03-07-2013 11:02 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
