Hello,
I am needing to do some maintenance on my old 97 dodge ram (my first car!) Its a 4x4, 5.9L Gas 1500 with 230k
I am going to tackle the climate control issue. My selector knob for airflow direction has zero affect on where the airflow goes! It just comes out of the top vents near the window.
What/where do I replace for this? Also, I often smell coolant in my cabin (slight) when I am driving for the first few miles. There must be a leak. Do you have any suggestions of where to look, common parts I should just replace?
Spin off of those last two: Could you guys direct me to some good websites to buy parts for my truck? I need a new dash, if there anywhere the sells a good one. If not, ill go to a yard.
Finally, my fuel pump just went out again after changing it two years ago. Other than making sure the voltage is correct to the fuel pump, is there anything else I can check/consider to make sure there is not something causing them to go out?
Thanks!
Thanks!
