jamesfarris
- Aug 15, 2017
- 10
- 0
- 1995
- 5.9
I have a 95 dodge ram 1500 4x4 with a 5.9. I just rebuilt the trans and put it back in and pinched a three wire bundle in the seam between the trans and the engine. I assume it is the crank sensor wires, however. these wires go out through a hole in the trans bell housing and the sensor is inside the space between the engine and trans. everything I have seen on the internet shows the sensor outside on the side of the engine. about an inch or so farther down the bellhousing there is a two wire sensor mounted and can be removed from outside the engine. it runs up to the wiring harness and goes into the harness with no plug. what is that? I cant find anything on this other sensor, and why is my crank sensor inside the space between engine and trans?
