jessejameslnw
- Aug 2, 2016
- 17
- 2
- 1998
- 5.2
My '98 2WD 5.2L flat out quit on me while driving... I've replaced the fuel pump, crankshaft position sensor, pickup coil, asd relay, fuel pump relay, and even borrowed a PCM from a similar truck to no avail. The truck started after fuel pump replacement with the borrowed PCM then died. Now she cranks but will not start... fuel pressure is 50 psi with the borrowed PCM and 0 psi with my original. No apparent fire, fuses all checked and good. I've read a ton of threads with similar symptoms but have yet to see a single solution which is why I've been tossing parts on it. She's been a rock solid truck and I need her back on the road. Any advise is appreciated.
