I don't disagree, everything you said is true. Yes, those giant fans take a lot of power to turn, just spinning them by hand you can feel how much air they realy pull. However, those are either ON or OFF (on the trucks with ON/OFF selectors you have a bit more control) on the older ones, and even on some new trucks. However, the newest engine i've worked on was a 2016 Kenworth with a brand new MX-13. I love that engine, almost as much as the old detroit engines (only for the sound of the old detroit). They have electronic controlled belt driven fans. They run based on the driver desired setting, or if they are getting too hot, the ECM turns it on and locks out the driver. Even on the 2016 base models its still only On or Off, not variable like automotive. However, the Cummins ISX has three options, ON/OFF, 3-Speed select, or Variable much like a viscous clutch. I love the ISX, just not in a Semi (just gotta put that out there). I have yet to see a semi with an electric fan, for a few reasons, reliability being the largest. However, with the newer 3 speed and variable designs, Semi fans can be almost as efficient as an electric fan with an order of magnitude more reliability.
