Engine Cleaning (post pics of yours)
bluwarguy
5.9 Magnum V8
Not sure if this is the right place to post it, but what's the best way to clean our engines? I'm sick of having mine look gross and dusty all the time. Also, post pics of your clean engine bay, let's see who has the best looking
THETANK
up jor *** mang
2015 R/T
not a ton of help I know but I start on day one right from the dealer, good luck.
dhumboldt12
5.9 Magnum
I would say what worked pretty good for me was just to take some degreaser from any auto parts store, cover the alternator and belt, and just start wiping down.
Sent from my Nexus 5X using Tapatalk
Max78
AZ
Magnum 5.9
I went to the coin wash that had a engine de-greaser option, hosed it down, sprayed de-greaser on heavy and blew it all away with the pressure washer. It looked like a new engine by the time I was all done and had no adverse effects.
I spent less than it would cost to buy a can of Gunk and used a ton of de-greaser, and it worked very well.
Stay away from all engine detailing products if you want it to look half way decent over a period of time.
Sorry, dont have any pics.
dudeman2009
Magnum 360
Any place that sells degreaser or a car wash with degreaser is the easiest way to go, just don't spray down the electrical boxes too much.
If not, soap and water works amazingly well, it just takes a bit more elbow grease.
After you get it clean, tire shine on all rubber parts and black plastic gives it a nice sheen for a bit until it gets covered in dirt and dust again.
If you want a clean engine bay, get ready to work for it, you almost need to clean it weekly or twice monthly.
Ram444
Cummins 6.7
Don't use Purple Power it will stain your hoses. I've had good results with Simple Green. Saying that, don't leave Simple Green on for more than a couple minutes.
Yeret
The Village Drunk
Under the hood fixing/breaking something.
5.9 Magnum
When my engine was out, I stood inside the engine bay and cleaned every square inch with diluted Purple Power. Cleaned up the intake manifold and valve covers and had the block painted. When the engine was dropped back in, it looked absolutely brand new. It took about two trips down the gravel to dust everything back up again, LOL. I do occasionally clean my valve covers along with a thing or two here and there especially when I pull the air cleaner to re-oil the K&N.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
i use the bulk degreser we have at work. Called Bluetek99. i just cover my air filter with a towel, saturate the engine bay with it, then fire up the washer and blow it all out
dudeman2009
Magnum 360
Man, I should've cleaned mine while the engine was out. :buffer:
CostaRam
Costa Rica
I particularly like your TRD cover!
Chris
