E4ODnut
- Oct 21, 2016
- 31
- 3
- Gibsons BC Canada
- 1995 Dodge Ram 2500 4x4
- 8L V10
2001 2500 4x4, 5.9, auto trans.
Got "check gauges" warning chime and indicator. Battery voltage pinned at ~ 18V, according to the instrument panel gauge.
I pulled over, shut the engine down and re-started. Everything good until I get home.
This sequence of events repeated itself for several days.
"OK" I sez to myself, " Should be nothing wrong with the alternator, must be the regulator circuit in the PCM". So, installed an external regulator. Same problem.
"So" I sez to myself, " I wonder if the instrument panel voltmeter is telling me the truth"?
I checked the voltage at the battery with the instrument panel gauge indicating ~ 18V. 14.8 V on my trusty Fluke 87.
No problem with the alternator or the new external regulator.
Ever since, when I take the truck out, it will give me the warning and high voltage on the gauge. I ignore it, and after several minutes, the voltage gets back to normal and the warning goes away. Sometimes it will stay this way until I get home, sometimes it will cycle several times until I get home.
What gives? Anyone ever have a similar problem?
