Turbo change on 2000 CTD
Warwagon
5.9l HO Cummins Turbo Diesel
How difficult is replace turbo and components? I do some shade tree mechanic stuff. Or should I take to dealer?
dapepper9
Iowa/Nebraska Border
5.9L V8
Honestly it's like swapping any other part. Pretty simple if the one you're installing is meant to be drop in, whether oem or aftermarket.
jlbayes
2001 & 1997
5.9l cummins
What other components? I can swap most single turbo stuff in under an hour pending no ridiculous rust issues. Soaking any and all hardware with penetrating lube on the hot side before working on it while hot helps a ton.
W
Warwagon
Well come on over and will get it done.
jlbayes
2001 & 1997
5.9l cummins
Where is over at? lol and what all needs to be changed?
W
Warwagon
Hamilton, Ohio. Most likely everything attach except exhaust.
jlbayes
2001 & 1997
5.9l cummins
Shew that is a bit of a ride for me. Upgrading turbos? Stock replacement?
W
Warwagon
Need advise upgrading. A little more would be nice. Found my big problem loose tube from turbo to intercooler.
jlbayes
2001 & 1997
5.9l cummins
Looking for more power? Lower egts? Better response?
jlbayes
2001 & 1997
5.9l cummins
Power will not be found without more fuel. Lower egts will get a trade off....less response. Better response will result in higher egts at wot.
Jems007
