MoparMagic'00
ok RF fam my truck came from momma mopar with the 118 amp alt.. I am wanting to upgrade to a larger amp alt however don't know what all fit for a larger output.. Ive seen the links for the 160 amp durango swap and that seems very do-able.. so how would i test the current amp of my altenator? (in case someone else has already changed it) and are there any ill affects of using a higher amp alt? will the pcm adjust to keep from over-charging? The reason for going larger is I am going to be running more lights and an aftermarket stereo system.. nothing note worthy just keeping strain down if i can thanks guys
Edit for info: 2000 1500 5.2 auto 4x4..
