RobinHood
- Nov 2, 2014
- 2
- 0
- 1996
- 5.2L v8 magnum
so, this isnt my truck, im on here trying to help my brother solve some problem with his truck.
he bought the truck from someone and they had a non-work radio(bad fuse) and A LOT of electrical problems...
they mostly revolve around the dimmer switch(which was replaced according to the previous owner), and the problems are like, the dome light is "always on" and when you try to use the dimmer to turn it off the light turns off for a fraction of a second on the click over from on/off.
we assumed it was the door jam switch causing the problem, and was recommended to take the switches out which should take the switch out of play when it comes to turning the light on, that didn't work.
and that really as far as we got to solving that issue, since we cant afford a new 80$ dimmer switch at the whim of it possibly being the problem, im hoping someone knows some better troubleshooting tips to narrow down the problem.(have asked a few mechanics, they all point to "have us fix it for you")
(the dimmer switch also controls headlights, yet the headlight DO turn on and off)
another issue is(atleast i believe this is an issue) is that the light around the ignition is always on, i don't know if thats normal but am worried it could kill the battery.
p.s it seems the radio 12V+ line has been re-ran because the fuze for the radio is not the one indicated in the manual(its now ran into the same fuse as the dome light)
-thanks in advance, i'm not great in automotive, so pardon me if im not seeming clear-
