1995 Dodge Ram 1500 5.2L 4x4
Hey guys, I'm working on changing the Ball Joints on this bad boy, so far I have everything pulled off, all ball joints removed and the bottom ball joints replaced, but I came to a stop
I'm following this tutorial How to: Replace Ball Joints - DodgeTalk : Dodge Car Forums, Dodge Truck Forums and Ram Forums (It's the only decent one I found)
It says to put the top ball joints on you need to have an angled spacer, I can see why you need it, however my kit from Oreily's didn't have an angled spacer, is it a big deal to use a straight spacer?
Anyone else have expierience using with these?
The other question is while I have the axle shafts out I noticed the have a fair amount of rust on them(Up until the geared parts), should I try to sand these down a bit while I have them out or just leave them be?
