Blendor Actuator?
speeddemon47
5.9 Magnum
I have a 97 1500. I don't have any heat (only lukewarm). both tubes going to the heater core are warm so I don't think it's blocked. I flushed the coolant system. I'm thinking it may be my blendor acuator. It should be a simple process but when I go to the passenger side where it should be I don't see it? All that is there is a round metal post that sticks through the black plenum case. When I move the air settings around the cylinder moves so I know im in the right spot. It's like this is where the blendor actuator should be but there aren't even mounting holes for it. What am I missing?
dapepper9
Iowa/Nebraska Border
5.9L V8
I've never really been in there so I'm not really sure what to suggest other than download the factory service manual here and go through that
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
94-8 there is no blend door actuator. The blend door is controlled by a metal rod that's controlled by a cable from the a/c controls. If your heat is luke warm either the door is stuck/broken or you have a problem with/in your heater core.
Goodie1990
