Engine dies at idle, even with new fuel pump. HELP!
KansasRam1997
Lawrence, KS
5.9L 360 Magnum
First, my truck began idling real low around 300-250 rpm along with low oil pressure light. Now it won't even stay running unless I keep my foot on the gas! When I press on the gas pedal the oil pressure goes back to normal range and oil pressure light goes away. However, as soon as I let off the gas it drops to zero and dies.
I thought it was the fuel pump, so I went ahead and replaced that. Replaced air filter. I believe i'm getting good fuel pressure from the pump because I put the fuel line in a plastic bottle, cranked the engine over and a generous amount of fuel poured into the bottle. Also, I tried cleaning my fuel injectors and still the same problem. When I rebuilt the motor (about 400 miles ago) I had replaced the Idle Air Control Valve on the throttle body.
I'm starting to think either 1) my timing went screwey, 2) I bought a cheapo Idle Air Control Valve that got stuck, 3) I need to check the throttle position sensor.
Any comments, questions, or concerns will help. Thanks ya'll!
dudeman2009
Magnum 360
Pull the brake booster line and start it. Oil pressure drops like a rock below idle, I wouldnt worry about that. Pulling the brake booster line will allow for airflow despite a bad IAC. If it runs nicely with the brake booster line off, i'd bet on the IAC. One of my old friends from school bought a gen 2, its beat to hell, his IAC was bad, despite my warning of cheap replacement parts, put a chinese IAC in there. What do you know, its bad again.
So now he's driving it without power assist brakes...
K
KansasRam1997
Lawrence, KS
5.9L 360 Magnum
I did exactly as you described and it runs smoothly! Those darn chinese sensors, never again! Will post update after putting a good Mopar sensor on
Gr8bawana
6.7 CTD
Let us know how it goes. A lot of people come here and ask for help and never tell us if their problem ever got fixed.
K
KansasRam1997
Lawrence, KS
5.9L 360 Magnum
Will let ya'll know this evening. I'm at school at the moment. Thanks, I really appreciate ya'll #RamFam lol
K
KansasRam1997
Lawrence, KS
5.9L 360 Magnum
UPDATE: put in the IAC sensor that came stock on the truck, it was still good even though I replaced it with the chinese one last November. My truck starts everytime and runs smoothly... Even feel a little more power from when I cleaned the fuel injectors.
MORAL OF THE STORY: don't but cheapo Chinese sensors. Get a good mopar one. The Chinese one lasted only about 400 miles! Spend more on quality
Gr8bawana
6.7 CTD
Good to hear you got the problem fixed. :favorites13:
