XxJamesAxX
- Dec 2, 2014
- 19
- 2
- 2002
- 5.9 V8
Ok guys i cant figure this one out hopefully someone can help,
When i start the truck the compressor kicks on and blows real cold air 42-44 degrees, but if for some reason you shut the air off after about 15 min or shut the truck off and restart it the compressor wont kick in. Kicker is though I've drove the truck for 30min plus without shutting it off and it does fine. It's only when you shut it off and restart it.
I've cleaned all connections and replaced the a/c relay switch with no help.
I hooked up a/c gauges and am getting Low: 87psi without the compressor running and 55psi with the compressor running. Apparently the gauge for the high side is not working though so i need to get another set and get a more accurate reading there.
Any info would be much appreciated im taking a 2hr plus trip next week and would like it have this figured out.
Thanks
Thanks
