Figured I better update this! The tranny was starting to grind quite often going into 4th gear. Mostly when downshifting from 5th to 4th. I changed the fluid out to Amsoil Synchromesh. First test drive it was better but still grinding. After a couple hundred miles of driving the grinding is totally gone! Amsoil gets my vote again! Oh, and for the allen wrench, the parts store wanted $23 for one. Went to the hardware store and pick up bolt with a 17mm head and a nut to match. Welded the nut to the bolt. Worked perfect. Cost...about $1.
