Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > Dodge Ram Cummins Diesel Forum > Rotary Pump
Rotary Pump
Reasonable horsepower?
This is a discussion on Reasonable horsepower? within the Rotary Pump forums, part of the Dodge Ram Cummins Diesel Forum category!
Just bought a 89' D250. What mods are recommended for moderate power increase? I really have a lot to learn ...
Like Tree8Likes
Reply
Old 11-05-2014, 03:03 PM   #1 (permalink)
Redtruck-VA's Avatar
Ram Year: 2003 & 1989 D250 RWD
Engine: Hemi-5.7, 5.9 12v & 24v diesel
Default Reasonable horsepower?
Just bought a 89' D250. What mods are recommended for moderate power increase? I really have a lot to learn and would enjoy hearing what folks are doing to pump up their older trucks.
Thanks,
Sponsored Ad
Register to remove this ad.
__________________
Greg 2003 SXT-Hemi SuperCharged, OCP manifold, billet CR 20" wheels, AeroForce gage, AFR, fuel Pressure, 46RH trans, Edge 3000, PPP Track Warrior, Shiftlite, TCI ProShifter, 180 stat, all aluminum radiator, HD Trans Cooler, DTT 4:10, LT's, Magnaflow duals cats, Mcgaughys 3/6 spindle kit, Monroe shocks, Caltracs, Aeon bumps, Roll Pan, shaved Ant, tail gate and cowl. And a 2007 QC manual trans/4wd diesel for a support vehicle.
Redtruck-VA is offline   Reply With Quote
Old 11-05-2014, 04:29 PM   #2 (permalink)
Ram Year: 2014
Engine: v6 3.6
Default
An older 89? You could pop on a cai, and a throttle body spacer, those would help.
__________________
2014 Ram 1500 SXT 3.6l DOHC VVT V6 8Speed - Diamondback tonneau cover: HAUL ON TOP! - Raptor Series wheel to wheel 4'' step tubes - Mopar tow hooks - Weathertech floormats - Krown rust protection - K & N drop in air filter - 6.5 quarts 5w20 royal purple - white - 21-27 MPG average
Grad12 is offline   Reply With Quote
Old 11-05-2014, 04:40 PM   #3 (permalink)
Default
Appreciate your input, it's a diesel...
__________________
Old 11-05-2014, 07:08 PM   #4 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
could intercool it. i don't know the best way to do it but it should help with power since your truck would have come from the factory with larger injectors
Redtruck-VA likes this.
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is online now   Reply With Quote
Old 11-05-2014, 07:24 PM   #5 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
you can get a bit more aggressive fuel pin and 3200rpm govener spring for $100 but you might want to get them gauges installed before you change that. adjusting the stock fuel pin is free
__________________
Old 11-05-2014, 07:40 PM   #6 (permalink)
Default
Inter Cooler in my book is always good. but is a problem on my truck as it has AC and I would need to lose both the AC and change the grille to the newer model. Keeping power reasonable I'm hoping watching EGT will be enough or add meth injection if more is needed. There is a lot I need to learn. This truck is my support vehicle used for towing and chasing parts. It's getting 21 mpg and seems reliable, I won't bitch...
__________________
Old 11-05-2014, 07:44 PM   #7 (permalink)
Default
I got a Dynamic Timing mod on order and will do gauges next, before messing much more with it. Tomorrow I'll replace ball joints and get the old girl aligned.
__________________
Old 11-05-2014, 07:51 PM   #8 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
you could still probably inter cool it without removing the a/c or upgrading the grille. you would just have to get creative. a aftermarket fuel pin should allow you to keep about your fuel mileage about the same except you usually get about 40hp more up top because the aftermarket pins are a bit deeper than the stock fuel pin. that up top where you would be getting that extra 40hp would also be where you got to watch the EGT.
__________________
Old 11-05-2014, 07:58 PM   #9 (permalink)
Default
Yeah, I need gauges next. Going to mount my tach pickup on the trans inspection cover as the pickup reads the flexplate teeth. Step by step.
__________________
Old 11-05-2014, 08:25 PM   #10 (permalink)
Cummins Powered's Avatar
Ram Year: 2008 Ram 2500 4x4 3.73 gears,1994 Ram 2500 4x4 12 valve modified, Industrial Injection #5 fuel plate
Engine: 6.7 Cummins, 5.9 Cummins
Default
With your truck you have the Bosch VE rotary pump, non -intercooled (89-91/2 models). Depending on how many ponies your looking to put under the hood, which you can easily modify your VE pump. You can add 40 to 60 horsepower, with an inexpensive fuel pin and spring, any adjustments can be made without removing the pump. The egt's will rise along with roaling some coal, an egt guage would be wise if you don't have one already. They also make a wide variety of turbo housings for your year make, that all result in a large turbo lag before the boost is developed. Just remember the more fuel, the more horsepower you create. If that's the case you will need larger injectors, modify the VE pump, transmission upgrade, larger exhaust, exhaust manifold, Fass/ Air Dog system, with head studs. The best way to build your truck is to add parts slowly but surely , instead of throwing parts all at once.
__________________
H&S Mini Max 225 tune,fire ring,Carrillo Rods,Helix 2 Cam,Hamilton valve springs,125HP nozzles,grid heater delete,ARP 625 with Vulcan gaskets,Air Dog II 200,Banks Ram Air,Banks Techni Cooler,Banks Super Scoop,Banks double shot water meth injection,BD intake manifold, DPP Spectre VGT turbo Howitzer 66 comp 67/70 with race gate, modified fuel rail, stroker CP3, Steed Speed competition manifold,Silverline 5 inch turbo back,NADP Heavy Hauler Race series transmission,Kore VR coils,Fox shocks.
Cummins Powered is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Reasonable price for '14 CC 4x4 Sport Poster General Discussions 7 07-07-2014 08:17 AM
This price seem reasonable? B-g-K General Discussions 19 04-24-2014 05:14 AM
Reasonable seat covers anywhere? NJ'12HemiExpress Interior 16 04-27-2013 12:21 AM
horsepower-enough is never enough.lol talon6 Engine & Performance 6 04-11-2013 05:47 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
