Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > Dodge Ram Cummins Diesel Forum > General Discussions
General Discussions
2014 Ram 2500 TPMS
This is a discussion on 2014 Ram 2500 TPMS within the General Discussions forums, part of the Dodge Ram Cummins Diesel Forum category!
Any of you guys that have recently bought a 2014 2500 or up know about the issues with the TPMS ...
Like Tree3Likes
Reply
Old 11-21-2014, 05:41 AM   #1 (permalink)
Ram Year: 2014
Engine: 6.7 Cummings
Default 2014 Ram 2500 TPMS
Any of you guys that have recently bought a 2014 2500 or up know about the issues with the TPMS being set at 85PSI and nothing the dealer can do to adjust the threshold if you put aftermarket wheels and tires on the truck. I just want to let you know that I contacted Ram and let them know how terrible of a design that was and the response was just about immediate. The issue was immediately escalated to the next level. The case manager told me that this was a big issue and that they have been receiving alot of complaints on it and that hopefully Ram will have a fix for it in the near future. If you have one of these truck, or even if you dont, I would urge you to go to ramtrucks.com and submit a complaint to help keep the pressure on until they change it. Just wanted to let you guys know that Ram is aware of the issue and are looking for a solution.
Power247 and mondo like this.
Sponsored Ad
Register to remove this ad.
reb4wd99 is offline   Reply With Quote
Old 11-21-2014, 05:54 AM   #2 (permalink)
Power247's Avatar
Ram Year: 2012
Engine: CTD 6.7
Default
This is good to know!! My '12 has the 'light load' TPMS switch on the dash and it is an awesome feature. I really don't understand why they pulled it from the '13+ trucks. Time to light up them phones!!
__________________
Build Thread Upgrading the factory Alpine system
2012 2500 4x4 CTD Big Horn CCSB 3.73|Flo~Pro|SIMS|XRT Pro w/MCC|Edge Insight CTS|Infinity|JBL
2009 1500 4x4 HEMI Big Horn CCSB 3.55|Volant CAI|18" Magnaflow|Airlift1000|Superchips Flashpaq 3865 - SOLD
Power247 is offline   Reply With Quote
Old 11-21-2014, 12:03 PM   #3 (permalink)
Cummins Powered's Avatar
Ram Year: 2008 Ram 2500 4x4 3.73 gears,1994 Ram 2500 4x4 12 valve modified, Industrial Injection #5 fuel plate
Engine: 6.7 Cummins, 5.9 Cummins
Default
That's Dodge for you lol! It seems like when they have something good for several years on their trucks, then they make all these improvements with the newer trucks, leaving out some of the great features that were on the previous trucks. I have the light load TPMS swich as well next to my exhaust brake button. Hopefully they will get that situated, that is a very great feature to have on the vehicle.
__________________
H&S Mini Max 225 tune,fire ring,Carrillo Rods,Helix 2 Cam,Hamilton valve springs,125HP nozzles,grid heater delete,ARP 625 with Vulcan gaskets,Air Dog II 200,Banks Ram Air,Banks Techni Cooler,Banks Super Scoop,Banks double shot water meth injection,BD intake manifold, DPP Spectre VGT turbo Howitzer 66 comp 67/70 with race gate, modified fuel rail, stroker CP3, Steed Speed competition manifold,Silverline 5 inch turbo back,NADP Heavy Hauler Race series transmission,Kore VR coils,Fox shocks.
Cummins Powered is offline   Reply With Quote
Old 12-01-2014, 11:00 PM   #4 (permalink)
Ram Year: 2014 2500 and 2004 2500
Engine: Cummins 6.7 and Cummins 5.9
Default
I called RAM and was told there was nothing they could do. After I complained they said they would have to call me back in a couple of days. They called over two weeks later and said there was nothing they could do and never said they were working on a fix. I just got tired of the lights so I have the 80 lbs. of air in the tires. I told my wife, "if I wreck while driving on ice, to sue the heck out of RAM". I can't think of anything more dangerous than driving on ice with an empty pick-up with 80 lbs. of air in the tires.
kdhawk200 is offline   Reply With Quote
Old 12-25-2014, 01:43 PM   #5 (permalink)
Ram Year: 2014
Engine: cummins 6.7
Default
I've been running my truck at 85, usually closer to 90lbs for close to 10 years with no problems.
If you have problems driving you should check into some winter driving classes or get yourself some better tires.
tony 340 is offline   Reply With Quote
Old 12-26-2014, 08:49 AM   #6 (permalink)
NWRQC's Avatar
Ram Year: 2013
Engine: 5.7 Hemi
Default
When people switch to an aftermarket wheel and tire set-up a lot of the tire options aren't rated for 85psi. When going aftermarket a lot of people tend to go towards an all terrain or mud terrain tire such as Nitto TG or Toyo M/T which are only rated for about 65psi, depending on size.
__________________
2007 6.7 | EFI-Live | Draconian tuned TCM | T4 S366 | ARP | AFE | Thuren | Fox | Carli
NWRQC is offline   Reply With Quote
Old 12-26-2014, 09:35 AM   #7 (permalink)
Darwin's Avatar
Ram Year: 2014
Engine: 5.7 Hemi
Default
I have a 2014 2500 with tpms and the door sticker says to set the front tires at 60 lbs. and the rear at 80 lbs. I have the tires set at 70 front and rear and the tpms low pressure light never comes on. Just thought I would share that little bit of info.
Darwin is offline   Reply With Quote
Old 01-02-2015, 10:03 PM   #8 (permalink)
AV8B6015's Avatar
Ram Year: 2014
Engine: 6.7 CTD
Default
The way I understand it, the light won't trigger until the rears hit less than 65 psi, but once the light is tripped, you have to air it up to 80 to get it to go out.
I am running 37's and they're rated at 65psi max. The light is driving me crazy.
I've read on another forum that if you take the TPMS sensors out completely, the yellow light in the dash goes out after a while and all you get is the tire screen on your EVIC when you start out. That might be my next move.
__________________
2014 2500 Mega 6.7CTD
2011 1500 Sport Crew 8.1" lift on 35's SOLD
AV8B6015 is offline   Reply With Quote
Old 01-03-2015, 07:29 AM   #9 (permalink)
Ram Year: 2014
Engine: 6.4 hemi
Default Got a tpms light on
Awesome sight by the way, have already gained some knowledge, had my 2014 2500 lifted and installed 35" tires they require less air in the rear than factory now I have a light on, four wheel parts in Orlando did the work, they did not offer any help in fixing the light and they did not say anything up front about this basically they suck. I have been doing my own research, will head to the dealership today they will attempt to lower the rear air requirements then I will have them air up to 80, I will drive it to trigger the light off and then air down as much as possible, will keep you informed, u guys already offered some advise appreciate it. I will also go online to ramtrucks.com and file a complaint this may help with our fight to fix this. I will eventually go higher with 37" tires but not yet love the beast 6.4 hemi four wheel drive 2500
The beast 2500 is offline   Reply With Quote
Old 01-03-2015, 11:15 AM   #10 (permalink)
AV8B6015's Avatar
Ram Year: 2014
Engine: 6.7 CTD
Default
Been there, done that. Had the dealership change the threshold, my dash says "inflate to 32 PSI" but the light still comes on whenever the rears are below 65. Good luck, and let us know how it goes for you.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
2014 2500 hemi 3.73 vs 2014 2500 4.10 Bigdaddy Towing & Hauling 55 10-15-2014 06:22 AM
what is this for? 2014 2500 tommy_harrell Tech Info 80 08-06-2014 10:22 AM
TPMS problem on a new 2500 HD Power Wagon Tech Info 1 06-03-2014 10:02 AM
FOR SALE: 2014 Express 20" Wheels and Tires, complete with TPMS *MARYLAND* mojoe For Sale 21 04-22-2014 07:13 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
