Meguire's Ultimate Black sucks?
Witch
Hemi 5.7 liter
Yup, it is the do all in a pump spray ..... lol
jlpowell84
jlpowell84
Well look at you guys lol.
Aerospace huh? So I'm good to launch into orbit then? :/
You know Jay I have been wondering if I got some of the Wolgang sealant on the black plastic when I did the sealant after the buff job...Wolfgang also makes a plastic product that is $20. I was so pleasantly pleased with the sealant I thought of giving it a try. But you havnt lead me wrong yet and both of you use this aerospace stuff so maybe I will give it a try.
Honestly it seems like these products that make the plastic wet are fine but soon as it rains they leave residue all down the paint which sucks and the plastic gets spotty and weird.
I did have success with the 6" section I put the Adams VRT Tire and plastic treatment on. So maybe I will do that and park it in the garage for 4 days or so. Really let it set in then go back and wipe like crazy with dry rag.
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
At one time or another we all used stuff that worked and some stuff that didn't. Sometimes it was a long and expensive journey. Try a couple of different things and see what works best for you and in some cases, what does the least amount of damage--LOL. Your truck reallllly looks good. You have done a great job. I'm glad you are satisfied with the combination of products that your using.
Jay
Scgirardi
Applied to much and didn't remove quick enough. When removing use a light damp cloth
Feli
Forever Black Bumper & Trim Dye Kit, I haven't used it but davidram has a thread about it
MTLHEMI
HEMI 5.7
Used it today with very good results :)
Depends on the technique maybe.
Sent from my SM-A500W using Tapatalk
Hot Ducer
Atlanta Ga
Youtube says to use a heat gun...
2003 1500 QuadCab 5.7 4x4
Slick61
It has been my experience that most of the water-based protectants will turn cloudy/milky if they get wet within a few days after application... even 303 Aerospace Protectant. Used to happen all the time on my '04 Saturn Vue bumpers... just had to keep re-applying to keep til they looked new again, then buffed off the excess with a clean, dry terry cloth/towel.
Bullitt5339
St Pauls, NC
I tried it with mine, but like everything else it's a very short lived fix and the gray comes back very quickly. I even did the heat gun and then the Ultimate Black to protect it and it came back in a couple weeks.
Hot Ducer
Atlanta Ga
Lame... I tried "back to black" on my jeep fenders, and the entire bottle was fine after a couple applications and back to looking creepy after 6 months so... Spray paint
alorac79
Martinez, Ca
Black Wow Pro is some of the best stuff I've seen and used. I had a 2000 Dodge Ram 1500 that that stuff worked miracles on. I plan on using it on my 2016. I've also had a good experience with Mothers Back to Black. It doesn'tas nearly as long as Black Wow Pro
alorac79
Martinez, Ca
Car Pro also has a product called PERL. I'm experimenting with it now.
Treburkulosis
Your High End Detailer
Haslet, TX
2012 Lonestar Edition converted over to a Sport
It's an ok product. Once things get grey pretty much nothing works except repainting it.
Goodie1990
