mikemc53
- Jul 14, 2015
- 2
- 0
- 2004
- 5.9L Cummins
This just started a few days ago. First of all it is a 2004.5 Ram 3500, 5.9L HO. When I turn the key in the ignition to the "run" position the pump (Fass) now runs about 25 seconds, when it used to run about a second or 2. It is also very loud.
I can start the truck anytime during this 25 second run-up and then the pump will continue to run and stay very loud after start-up. If I let the pump run until it shuts off I can start the truck and the pump will not be running...initially. Then it will sporadically go on and off (again quite loud) but if I hit the accelerator as soon as it starts, it will stop...and then in about 10-15 seconds it will do it again.
Sounds like the pump is going but, then again, it could be a filter issue or tank issue. I checked the lines at the pump and they seem to be on clean with no air suction issues.
Thoughts? I am supposed to take a short trip (about 120 miles) on Monday and have little time to do anything with this.
