Lift pump issues
Discussion in '5.9 Common Rail' started by mikemc53, Sep 24, 2016.
  1. mikemc53
    mikemc53 Junior Member
    Jul 14, 2015
    Ram Year:
    Engine:
    5.9L Cummins
    This just started a few days ago. First of all it is a 2004.5 Ram 3500, 5.9L HO. When I turn the key in the ignition to the "run" position the pump (Fass) now runs about 25 seconds, when it used to run about a second or 2. It is also very loud.
    I can start the truck anytime during this 25 second run-up and then the pump will continue to run and stay very loud after start-up. If I let the pump run until it shuts off I can start the truck and the pump will not be running...initially. Then it will sporadically go on and off (again quite loud) but if I hit the accelerator as soon as it starts, it will stop...and then in about 10-15 seconds it will do it again.
    Sounds like the pump is going but, then again, it could be a filter issue or tank issue. I checked the lines at the pump and they seem to be on clean with no air suction issues.
    Thoughts? I am supposed to take a short trip (about 120 miles) on Monday and have little time to do anything with this.
  2. dmuney
    dmuney Member
    38
    38
    Mar 2, 2016
    Ram Year:
    2005
    Engine:
    5.9L HO Cummins
    Take your filters off and remove the tube that goes Dow inside the filter make sure there isn't a piece of something sucked up in there. Sounds like your fass pump is cavitating which would make it very loud or its time for a pump
    05 2500 4WD swb AFE intake Edge Attitude 4"ex down 1/2 cylinder White on Black
  3. BWC
    BWC Member
    80
    Sep 2, 2015
    Northern CO
    Ram Year:
    2003
    Engine:
    Cummins
    Is it holding pressure just fine? Yeah sounds like something could be in the filters.
Share This Page
