SRT-10 1/4 mile
homsh
leonardtown, MD
My quad with cat back and a tune was mid 13's all day at 102 on street tires.
Farmer Fran
Earth
2020 Limited Loaded - Sold
The 4-speed Auto is the Achilles Heal - Well that and 5500 LBS :)
Saltillo Express
Florida
Mine was mid 13's. The 46RE IS the choke point on the quad cab. Dave Kaspar flashed mine. I miss it too.
12lowram
Tucson, AZ
HEMI 5.7L
Although this is an outdated/abandoned convo. Maybe someone else looking for info might use this. I have a '05 Ram SRT-10 Quad Cab; only mods are Volant CAI and resonator delete. Ran it down in Arizona Southwest International Raceway. Temps were 103 for all my runs, barometric pressure was like 29.8, had around 7% humidity, and elevation is around 2600' above sea level. I ran on HORRIBLE street tires and could not get traction through first and some of second. Ended up running an average time of 14.4 to 14.6 ending around 93-97mph launching with tow/haul on and from around 1k RPM.
Case in point. I believe its all about location. An Srt-10 in Arizona will run completely different than one say in Flordia, California, etc... If you've actually ran your truck at the 1/4, use the link below and pick a racetrack. Its amazing what elevation and air density can do to your times/speed. Hope this helps someone. Me personally, I'm going back to central California and might run at Sacremento Raceway. Hoping for a 13.8 @ around 100-103.
DA Calculator - Density Altitude Calculator - DragTimes.com
Budakane
Northern VA
345ci Hemi
I know this is an older thread, but I am wondering what my odds would be against a RC & a QC SRT10? I have listed my mods to date below.
http://youtu.be/AXcpo5QMZk0
https://www.youtube.com/watch?v=a7Ok...ature=youtu.be
* 5.7l Hemi * Vararam * 90mm TB * Crazy Spartan Cam * LT Headers/3in Y-pipe * 93 Octane Tune * 3in Cherry Bomb * 3in Cutout * 4:56 Gears * Sonnax Line Pressure Booster * 180 T-Stat * 3000 Stall * 17in ST Wheels * M&H Drag Radials * Traction Bars * Sharadon Stage III Valve Body * Next : 150 Wet Shot
ST-8
Not good odds imo,
Goodie1990
