Cabin Air Filter Mod
Texasez
Dallas tx
I had them look up the avenger to find the one I have. Still seem to be having trouble though.
audio1der
Airdrie, Alberta
Handing the tectonically slow parts tech at my local dealership the following on paper, copied from page 1 got me the right parts.
(1) Filter box 'lid'. Dodge part number 68052292AA (About $11)
(1) Cabin Air Filter. Dodge part number 5058693AA, OR, Purolater C25869 ($7), Hastings HAAF1328, or Wix 24578
(These parts are all "OEM" for a 2010 Dodge Avenger, Caliber, Compass, etc. They will not be found by searching in any parts book under 'Dodge Ram'!)
I did have to reassure him several times that I understood what I was doing was NOT meant to fit my vehicle and I knew I couldn't return the parts.
Chewy
Bettendorf IA
V8
Just ordered mine.
Sent from my Nexus 4 using Tapatalk 2
Funny! I ordered from the SAME place! Mine was 2 bucks more though. I must live further from the warehouse. lol
Chris
There's two threads about the same subject. Can admin merge them and make it sticky?
20ram12
Louisiana
Cutting the plastic was a little bit of a pain but, great mod. My allergies don't seem to be as bad.
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
It's pollen season in the mid-atlantic region and the inside of my truck is full of dust within hours after a wipe-down--it is time to undertake this mod. :Pshyco:
Justinpack123
It works great! I also sprayed my filter with cologne so that my truck would smell better. It is really an easy mod. I was worried about cutting into my truck but once I did this I'm glad I did because I have another 4th gen and the ac is messed up now because its at the beach a lot and I wish I would have done it to that before as well
audio1der
Airdrie, Alberta
Even my UBER-protective of the truck wife, was OK with this mod.
In-cabin filter and catch can; tie for mod every 4th gen owner should have.
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
I just called this company and they told me this would not fit my 2013 '10-'12 Dodge Ram Cabin Air Filter Kit-Geno's Garage
Anyone know where I can get the filter and door for my 2013?
I haven't seen where any 2013s have done this mod yet, so I don't know whether anything has changed between the 2013 and all the previous Gen 4 Rams. If so, Chewy ^^ is gonna be pissed, because he's bought the parts and doesn't have his Ram yet. :025:
Per the orignial post (bumped about 40 times now) the parts are not for any Gen 4 Ram. They aren't indexed that way and you can't order them that way.
They are for a 2010 Dodge Avenger. If your 2013 air system is the same as the 09 -12 Rams, you can cut out the marked partition behind your lower glove box and install this mod yourself.
Asking someone for the parts for a 2013 Ram 1500 cabin air fliter will get you a cross-eyed salute everytime. :shrug: :nono: :sad72: :thumbsdown: :wtf: :Nonono: :bleh: :death:
Hornet
Banned
I just did my 2013,it's identical to the earlier Gen 4's.
I ordered the cover for a 2010 Journey/Calibre,and it popped right on.
Casper
U.S. Navy (Ret.)
Springfield, VA
5.7L
URdone21
CA
2013 Quad Cab
According to Hornet , it works good lasts a long time.
He used 2010 Journey/Caliber parts for his 2013--bet that's the same part as the 2010 Avenger.
So would the parts in the link I posted work then?
Hornet
Banned
Whoever posted the Chrysler part numbers are the ones i used,it showed up at the local dealer as a 2010 Journey cover,but the bag lists a whole bunch of applications,so i think it's pretty well a universal cover.
You're heater box should look identical to the ones shown in the posts earlier.
Just follow the earlier reconmendations .
Just a heads up though,use a very sharp blade.
I drilled small holes in the 4 corners then cut between the holes,the holes make for a cleaner corner cut
URdone21
CA
2013 Quad Cab
Did you order it online? If so, link please.
Hornet
Banned
Nope,local Chyrsler dealer,that way if it didn't work at least it's returnable.
Also a firm believer in supporting my local places of business
audio1der
Airdrie, Alberta
Have you '13 guys looked behind your glove compartment to see if the panel looks the same as the 09-12s? If so I would not worry one bit.
