How to aim your headlights - 4th Gen Rams
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Quite simple!
There is a hole in the fender, next to the key here:
You'll need a ratchet, an extension and either a 7MM or T20 bit.
Here is what the adjuster looks like:
couldn't get the camera to focus (stupid phone), but this is a 7MM
Crank away! Clockwise = up!
EJM05
Somers, CT
440 Big Block
Damn.... so this whole time of me taking the headlight out and adjusting it and putting it back in then taking it back out (you know what i mean) could all be solved this way. ah well.... now i know a easier way.
LB3711
Trumbull, CT
3.6L V6
What!?!:roflsquared:
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Say what?
This is for the vertical aim on the headlights. Projectors may need a slight horizontal adjustment, which is totally different. ;)
quietpeen
2021 TRX
Hellcat
sweet....so before i level or get new lights, I think i should mark my garage door with tape so i know where to adjust them back to.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
assuming they are right from the factory. LOL
Best way to do it.............measure where you are, then 25ft away, 2" drop. Easy.
cody0707
4.7L
With HIDs will I have to worry about horizontal adjustments or will it only be vertical?
All I am doing is swapping the OEM with the Retro kit.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
you may want to go lower. ;)
Musclemckeester
Houston, TX
n/a
n/a
Does that go for me with a 8" lift?
That's a good question. I finally remembered to adjust mine down (after 3 months now). I was wondering if there was a rule of thumb for it. I just took a guess - I am sure they are better than they were. Never realized it was so easy to do or I would have done it sooner.
Mad Cow
Anchorage, AK
Cummins 6.7
I adjusted mine at first down way to low. I did not notice until this past weekend when I went out duck hunting. As soon as I got away from the lights I could hardly see the road. I had to run my HID driving lights to see and by the way they are awesome. I now adjusted them back up some. I feel it is too high in traffic in the city but on the HWY the still seem too low. I just don't know any more.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
being that high up..........well...........kinda stinks for lights and keeping it out of people's eyes. I suggest projectors. LOL
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
I gotta poke and prod every once in a while. :D
LB3711
Trumbull, CT
3.6L V6
You will after tomorrow. Lol
Sent from my AT&T iPhone 4.
quietpeen
2021 TRX
Hellcat
what time are you leaving...i won't see them if it isn't dark....lol
LB3711
Trumbull, CT
3.6L V6
Who knows. I'm not working Monday.
I'm staying at Craig's this weekend.
ChloeBrooks
