How to debadge... The right way!
BlackedOutHemi
DFW, Texas
2012 & 2012
5.7L HEMI & 6.7L Cummins
Grab 'GOOF OFF' from Home Depot! This requires NO elbow grease at all. Simply rub back and forth till its gone. It rubs off with almost little to no pressure
Or use the eraser wheel
Is that stuff safe for the paint? On the back it says damages most automotive paints.
fastNugly
Toronto, ON
2012 Dodge Ram Sport CC
It did absolutely nothing to mine.
I did however wash it off with soap right after all was removed and then waxed, but no, it did not do anything
MADDOG
Living in a Firepit
6.4L HEMI
If your trim is old, that pull at 45 degrees crap won't work.
But 3M Adhesive Remover will. :D
RamFan2
Same here. As soon as I saw how easy it was, I went straight to the garage and took 'em off. Looks so much better. Great video.
Miami Son
Banned
Port St. Lucie, FL
2012 Ram 1500 Sport Crew Cab
Tried to do mine today. No way that foam is coming off as easy as it did in the video, not on my truck. Both my thumbs are blistered and I only got 3 letters off. Goo Gone is a bust, too. Acetone worked great at getting the residue off and some Mother's wax with an electric buffer made it look great. Will have to wait for my thumbs to heal before tackling any more. What a chore.
fastNugly
Toronto, ON
Really? Your truck is new too!
I tried this on mine and my other car (2 years old) and worked exactly as Trupiano showed in the video.
I was amazed at how easy it was without an eraser wheel.
Thanks again Trup
pd298
SE Oklahoma
I really want to get mine debadged
So get off the computer and do it!
I used my gf's hair dryer to heat up the letters. worked great, then used a 3m eraser wheel to get the adhesive off.
BlackedOutHemi
DFW, Texas
2012 & 2012
The heating up works great!
Miami Son
Banned
Port St. Lucie, FL
I tried a heat gun and those were the spots that were the hardest to get off. I wonder if they use a different adhesive material between batches because mine have been a ***** to get off so far using the methods in here. On my 2000 it was way easier.
2012 R/T Joe
South Jersey
I wrapped fishing string around Popsicle sticks..like dental floss around your fingers...then used a sawing action and they popped right off. Had my buddy catch them so they didn't get scratched on the floor. The backing peeled right off, pulling away at a 45 degree angle away from the backing. Any residue came off with goof off.
fastNugly
Toronto, ON
Exactly how I did mine.
Good Off works much better than Goo Gone
