How To: 13-14 premium cluster upgrade
Riddawg
Florida
Cummins 6.7
What bluetooth obd2 reader are you using?
What phone/tablet are you using?
2018 2500 6.4L Hemi Tradesman
1990 5.9L 12v Cummins W250
OBD Link MX+ and it’s an galaxy 3 phone that I use just for obd cause I actually have iPhone.
swoyekr
SE PA
Hello all, I got a 2017 cluster for my 2013... seems like that might have been a slight mistake. Everything works fine but the TPMS obviously and the P flashes in the bottom. Trying to decide if I should sell on ebay and look for a 2013. Man what a difference though on usability. Anyone know how to make that flashing P go away? I can deal with the TPMS
SitKneelBend
St. Louis
3.6 Pentastar
I would sell it and look for a 13. I use a 2013 cluster in my 2014 and had the same issue you describe (flashing P) when I tried a 2019 cluster but TPMS worked. I believe their was a transition on the TPMS for 2014 on.
clifford15
CTD
The flashing P is because the cluster is from an 8 speed and the truck is a 6 speed. Might also do it in the opposite configuration. Different issue from the TPMS mis-match.
Gordo2212
Mississippi
2018 3500 Tradesman
6.4 L Hemi
Looking to upgrade my 2018 3500 tradesman cluster. Is there any difference from 2016-2018 clusters? The ones from 2016 are way cheaper on carpart so I’ll go with 2016 if there’s no reason to get a newer one.
SitKneelBend
St. Louis
3.6 Pentastar
I think you'll be good but they are fairly easy to sell if its not right.
swoyekr
SE PA
Thanks guys, I decided to grab a 13. Should have done my research.
SitKneelBend
St. Louis
3.6 Pentastar
My 8 speed also did the flashing P...
Athlium
Tacoma, WA
3.0L EcoDiesel
I just installed a 2016 into my 2018. took all of 20 minutes. So far so good.
swoyekr
SE PA
So I installed a 13 cluster, and now I have a new problem. The voltage, Fuel Filter, and TPMS are all blank. THe TPMS I'm not completely worried about because it worked initially but also didn't work on the old cluster, I believe the wheel units are the culprit there. However, the fuel filter being blank and voltage is concerning.
Vin was learned to the cluster, mileage and hours corrected.
To be clear, my truck is a 2500 and I was installing a 1500 cluster without the DEF gauge. I was under the impression that this shouldn't be an issue since the cluster's inner workings are the same. Am I off base here?
278877801_10110476302901883_1953765854330974055_n.jpg278590165_10110476302951783_7467680171429410548_n.jpg278447882_10110476302926833_6867165709006658983_n.jpg
SitKneelBend
St. Louis
3.6 Pentastar
View attachment 491625View attachment 491626View attachment 491627
I'm not sure about diesel to Gas compatibility but I've seen the compass heading blank similarly due to incompatibility when a particular radio was installed (for some reason). All this to say it may not be caused by what you'd expect.
spacex
NH
Just picked one of these up for $335 with almost identical miles to my truck. Looking forward to installing!
spacex
NH
…can you test before putting into the truck? This is box I received…. Gauges appear to be in good shape but I don’t want to tear apart the dash if it’s already *****. EA1A276D-6A70-4EDC-9709-85B49EF43749.jpeg
SitKneelBend
St. Louis
3.6 Pentastar
spacex
NH
Got it. Will test it out…
swoyekr
SE PA
I've recently started grabbing these when I can to resell on ebay. If someone looking for something specific let me know I'll see what I can find for you.
t0ymach1n3
Dallas, TX
5.7L???
I want to add my 2014 had a Rebel cluster from a 2017 and I had the flashing P when in park from day one. It never stopped. I recently did an 8 speed swap in my truck and I noticed recently that it doesn't do it any longer. Not saying the two are related as I also just recently finished the keyless entry and push to start ignition. I'm not sure which one fixed it but it hasn't done the flashing for the past few weeks that i've noticed.
Jems007
