Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram General Forum > Garage
Garage
DiabloSport Tuners - Discussion & Help Thread
This is a discussion on DiabloSport Tuners - Discussion & Help Thread within the Garage forums, part of the Dodge Ram General Forum category!
Which is the best model unit to buy for the most control and parameters on a 2011 or does it ...
Like Tree2Likes
Reply
Old 10-29-2015, 09:00 PM   #11 (permalink)
R/T_Fire's Avatar
Ram Year: 2011
Engine: Hemi 5.7
Default
Which is the best model unit to buy for the most control and parameters on a 2011 or does it matter? or more so what is the difference between Trinity Tuner and DiabloSport i2 DCX tuner, is it just the gauge option? cause I read Hemifever tunes available for both.
Sponsored Ad
Register to remove this ad.
__________________
2011 R/T - Motor: Diablo T-1000 w/ hemifever, Vararam intake - Susp: Beltech 3/5 drop, hellwig swabars front/rear with adjustable links, full Spohn adjustable rear components. stock r/t wheels and rubber
14.62 1/4 baseline low 12's current goal
R/T_Fire is offline   Reply With Quote
Old 10-29-2015, 10:09 PM   #12 (permalink)
MADDOG's Avatar
Super Moderator
Ram Year: 2014 Big Horn Crew
Engine: HEMI 6.4L
Default
The programmer parameters are the same between the two. The only difference is the real time gauge monitoring feature of the Trinity.
If you don't want or need that then save some bucks and get the DCX InTune.
__________________
MICHAEL
SUPER MODERATOR
2014 BIG HORN CC / 6.4L HEMI
AFE / ARMA COAT / BFG KO2 / DIABLOSPORT / HEMIFEVER
MAGNAFLOW / N-FAB / PIAA / PRO TECH / TUFF COUNTRY / WALKER EVANS RACING
MADDOG is offline   Reply With Quote
Old 10-29-2015, 11:23 PM   #13 (permalink)
Hemi450hp's Avatar
Ram Year: 2011 Ram 1500
Engine: 5.7L Hemi
Default
Trinity gives you the monitor to view gauges and record 0-60, 1/8th, and 1/4 mile times. It loads tunes faster and is easier to datalog with. It also works on just about every American made vehicle from 2000-up.
The i2 gives the exact same tuning as the Trinity, but you do not get the monitor. You can still datalog with the i2, but its a little slower and more difficult to use for logging purposes. The i2 only works on Dodge, Chrysler, Jeep vehicles. 1 big plus for the i2 is that you can buy extra tuning certificates which will allow you to tune more than 1 vehicle with the same tuner. They have to be Dodge, Chrysler, Jeep, but it is a feature that you don't get with the Trinity.
__________________
2011 Ram 1500 - 11.99 @ 110.66MPH N/A
2011 Ram 1500 - 11.09 @ 120.13MPH Nitrous
2014 Ram 1500 - 12.38 @ 109.61MPH N/A
Hemi450hp is offline   Reply With Quote
Old 11-05-2015, 04:49 PM   #14 (permalink)
R/T_Fire's Avatar
Ram Year: 2011
Engine: Hemi 5.7
Default
Thats is a huge plus for me as a charger and jeep are soon to be purchased in the next few months.
__________________
Old 01-30-2016, 05:01 PM   #15 (permalink)
Paluby's Avatar
Ram Year: 2014
Engine: 5.7 Hemi
Default
So if you have your trinity in monitor mode often when you are driving and don't half the monitoring when you shut the vehicle down why does it make your dash lights stay on?? Yet if you halt the monitoring truck shits down like it should.
__________________
2014 Ram Sport - A whole lot of pretty with a rumblin engine.
Future mods - smoked puddle lamps, Moe's HPS Cam, torque converter for 8-speed.
•Payin' the dough, to play in the snow • Born n Bred to Rip n Shred•
Paluby is offline   Reply With Quote
Old 02-07-2016, 08:34 PM   #16 (permalink)
craigsez's Avatar
Ram Year: 2016
Engine: 5.7
Default
PALUBY..try using spell chk....Once the engine SHUTS down and your key is out,nothing should be on but your trinity..It will stay awake till you unplug or goes into sleep mode..It will still draw power from battery so dont leave it plugged in for an extended time and not run the trk..
craigsez is offline   Reply With Quote
Old 02-09-2016, 04:32 AM   #17 (permalink)
Paluby's Avatar
Ram Year: 2014
Engine: 5.7 Hemi
Default
Spell check*. Got it. Thanks. Anyways, I'm saying that the DS Trinity does indeed go into sleep mode but if I leave it in monitor mode and walk away with my truck SHUT off the dash lights will flicker every so often even though the DS Trinity switched from monitor to sleep mode. If I press the exit mode which takes the DS Trinity back to the main menu and than shut the vehicle off or unplug the DS Trinity and shut the vehicle off my dash lights turn off and stay off. So something with the monitor mode is causing power to be sent to the dash.
__________________
Old 02-09-2016, 10:29 AM   #18 (permalink)
popcenator's Avatar
Ram Year: 2012
Engine: Hemi 5.7
Default
If you're seeing this with the truck off I'd just play it safe and unplug each time. I leave mine in and in monitoring mode and haven't had an issue yet. I've been doing this for a couple years now. The only issue I have when leaving the Trinity plugged in is the remote start range is greatly reduced.
Sent from my Nexus 6P
__________________
2012 Big Horn - True Blue - 3.55 open differential
Mods: 14" Magnaflow Tru-X | VR Air Grabber | DST - Hemifever Tune | 87mm TB | BT Catch Can | 180* T-stat | 2.1" Bilstein Level | 275/65/20 Nitto Terra Grapplers
popcenator is offline   Reply With Quote
Old 03-18-2016, 12:54 PM   #19 (permalink)
Ram Year: 2014 big horn
Engine: Hemi 5.7
Default
Seems like a good place to post this:
CMR Tunes written for a Predator can be used for a Trinity and vice versa.
Intune and IT2tunes are not compatable/ they are different. So If you upgrade to a IT2 from a predator Or decide you want to sell yout trinty and use a IT2....and you have a CMR tune you will need to have it changed by your CMR tuner.
Rupert is offline   Reply With Quote
Old 05-11-2016, 04:34 AM   #20 (permalink)
Bird's Avatar
Ram Year: 2014
Engine: Hemi 5.7
Default
Originally Posted by jbr View Post
Does flashing so many times hurt the PCM?
Is anybody able to answer this?
Bird is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
2012 Bloomsburg PA Ramforum.com meet and greet discussion thread! rocket Regional 63 07-04-2012 05:02 AM
No tuners :( Captain McGillycutty Engine & Performance 15 11-14-2011 11:42 PM
Computer tuners SnoRider Engine & Performance 13 04-25-2011 12:49 PM
Any GOOD Diablo tuners on here? truckin151 Engine & Performance 19 08-11-2010 09:40 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
