jhorst
So I put some high doors and a high ceiling in my garage/shop that I just built. 9' doors and a 14' ceiling. When they put the the doors in, they made it so that they opened and were as close to the ceiling as possible (~ 13'), instead of opening just above the top of the door (at about 9'). I bought the conventional garage door openers, that have the track and pull the door open/closed with a chain or belt. I just realized these wouldn't work since they pull back and my door needs to be pulled vertically for ~ 3' before it reaches the bend in the track and then slides horizontally. Upon some quick research, I only see a few of the "jackshaft openers" available most notably the Liftmaster units, but they are really expensive compared to the others. Just wondering if anyone has this type of opener or any other suggestions...just wanted to see what others have done before I pull the trigger on some $600 openers ($300 a piece).
