Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram General Forum > Garage
Garage
Warranties and aftermarket parts
This is a discussion on Warranties and aftermarket parts within the Garage forums, part of the Dodge Ram General Forum category!
Lately Ive been reading about guys worried about voiding their warranties, when adding aftermarket parts. Here's some education.... *Please Sticky* ...
Like Tree10Likes
  • 8 Post By Big Boi
  • 1 Post By charonblk07
Closed Thread
Old 01-10-2012, 06:19 PM   #1 (permalink)
Big Boi's Avatar
Ram Year: 2009
Engine: Hemi 5.7L
Default Warranties and aftermarket parts
*Please Sticky*
SEMA - Page 7
New Vehicle Warranties And Your Rights
No properly installed product on your vehicle will void your original vehicle manufacturers warranty. However, if you experience a problem with an uncooperative dealership point out the provisions of the Magnuson-Moss Warranty - Federal Trade Commission Improvement Act. For more information call your vehicle manufacturer or click on the link above to go directly to the Federal Trade Commission's website to find out about this law.
It has been established that a dealer may not deny warranties for new vehicles, unless the warranty claim results from the installation of specialty equipment. In fact, warranty-related materials published by the new vehicle manufacturers state that the installation of aftermarket parts have no effect on the warranty unless such equipment causes the warranty claim. Nonetheless, some dealers have improperly denied warranty claims even though the claim had nothing to do with aftermarket parts.
SEMA (Specialty Equipment Market Association) is very interested in hearing about any cases that have gone to court and any opinions that have been issued from courts on this issue. It is their hope that they will be able to use these court opinions to encourage the vehicle manufacturers to properly instruct dealers on the appropriate circumstances for denial of warranty claims. If you are currently having issues with a dealer over a warranty claim, please contact us for SEMAs contact information on this issue.
FTC Consumer Alert
Auto Warranties, Routine Maintenance and Repairs:
Is Using the Dealer a Must?
If you own a car, you know how important it is to keep up with routine maintenance and repairs. But can a dealer refuse to honor the warranty that came with your new car if someone else does the routine maintenance or repairs?
The Federal Trade Commission (FTC), the nation's consumer protection agency, says no. In fact, it's illegal for a dealer to deny your warranty coverage simply because you had routine maintenance or repairs performed by someone else. Routine maintenance often includes oil changes, tire rotations, belt replacement, fluid checks and flushes, new brake pads, and inspections. Maintenance schedules vary by vehicle make, model and year; the best source of information about routine scheduled maintenance is your owner's manual.
What is a warranty?
A warranty is a promise, often made by a manufacturer, to stand behind its product or to fix certain defects or malfunctions over a period of time. The warranty pays for any covered repairs or part replacements during the warranty period.
Do I have to use the dealer for repairs and maintenance to keep my warranty in effect?
No. An independent mechanic, a retail chain shop, or even you yourself can do routine maintenance and repairs on your vehicle. In fact, the Magnuson-Moss Warranty Act, which is enforced by the FTC, makes it illegal for manufacturers or dealers to claim that your warranty is void or to deny coverage under your warranty simply because someone other than the dealer did the work. That said, there may be certain situations where a repair may not be covered. For example, if you or your mechanic replaced a belt improperly and your engine is damaged as a result, your manufacturer or dealer may deny responsibility for fixing the engine under the warranty. However, according to the FTC, the manufacturer or dealer must be able to demonstrate that it was the improper belt replacement rather than some other defect that caused the damage to your engine. The warranty would still be in effect for other parts of your car.
Will using aftermarket parts void my warranty?
No. An aftermarket part is a part made by a company other than the vehicle manufacturer or the original equipment manufacturer. Simply using an aftermarket part does not void your warranty.
The Magnuson-Moss Warranty Act makes it illegal for companies to void your warranty or deny coverage under the warranty simply because you used an aftermarket part. Still, if it turns out that the aftermarket part was itself defective or wasn't installed correctly, and it causes damage to another part that is covered under the warranty, the manufacturer or dealer has the right to deny coverage for that part and charge you for any repairs. The FTC says the manufacturer or dealer must show that the aftermarket equipment caused the need for repairs before denying warranty coverage.
Tips To Avoid Warranty Issues
Here's how to get the most out of your vehicle's warranty:
Read your warranty. Often bundled with your owner's manual, the warranty gives a general description and specific details about your coverage. If you have misplaced your owner's manual, look for it online. Check the Owners section of your manufacturer's website.
Be aware of your warranty period. If problems arise that are covered under the warranty, get them checked out before the warranty expires. Service your car at regular intervals. This is a good idea in any case. But for the sake of keeping your warranty intact, follow the manufacturer's recommended service schedule. Details are in your owner's manual.
Keep all service records and receipts, regardless of who performs the service. This includes oil changes, tire rotations, belt replacement, new brake pads and inspections. Create a file to keep track of repairs; it will come in handy if you have to use your warranty. If you ever have a warranty claim and it appears that you did not maintain your vehicle, your claim could be denied.
Complain. If you think a dealer's service advisor denied your warranty claim unfairly, ask to speak with a supervisor. If you still aren't satisfied, contact the manufacturer or go to another dealer. You also may wish to file a complaint with your state Attorney General, local consumer protection office, local Better Business Bureau or the FTC.
For More Information
Visit ftc.gov for free information on buying, financing, leasing, renting and maintaining vehicles.
The FTC works to prevent fraudulent, deceptive and unfair business practices in the marketplace and to provide information to help consumers spot, stop and avoid them. To file a complaint or get free information on consumer issues, visit ftc.gov or call toll-free, 1-877-FTC-HELP (1-877-382-4357); TTY: 1-866-653-4261. Watch a new video, How to File a Complaint, at ftc.gov/video to learn more. The FTC enters consumer complaints into the Consumer Sentinel Network, a secure online database and investigative tool used by hundreds of civil and criminal law enforcement agencies in the U.S. and abroad.
Sponsored Ad
Register to remove this ad.
__________________
BBK Shotrie's - SS Flowmaster Super 44 - Magnaflow "Y" - K&N 77-1561KP - 180 Tstat - Billet Water Neck - 12" Chrome tips - Resonator Delete - 3865 - Homebrew Catch Can - Train Horns - Hella's "Behind the Grill" - 6K HID's - Tinted Tails -Painted Heads - Belltech 2/4 - Skar Audio/HAT build
Big Boi is offline
Old 12-26-2013, 02:32 PM   #2 (permalink)
charonblk07's Avatar
Ram Year: 2009
Engine: F1-A forged 349ci
Default
Canadians should be aware that we do not have anything comparable to the Magnuson-Moss Act. Warranties are at the discession of the dealership when it comes to aftermarket parts.
MarkV likes this.
__________________
'09 Ram 1500 Sport 4wd Green Mamba- 4.5/6.5 dropped, forged 349 block, cog driven F1-A Procharger
charonblk07 is offline
Old 03-22-2016, 07:07 PM   #3 (permalink)
Ram Year: 2016 ram 2500 Big Horn
Engine: Cummins 6.7
Default
nice post
Karstensdad is offline
Closed Thread
Bookmarks
Tags
aftermarket parts, warranties, warranty claim
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
OEM? Aftermarket? Nesto1000 RockAuto 3 11-08-2011 11:26 PM
Mygig vs. Aftermarket macked Audio & Electronics 7 10-18-2011 06:59 PM
MOPAR Aftermarket ltcoliver General Discussions 5 10-10-2011 09:14 PM
aftermarket hu TheSatinPumpkin Audio & Electronics 6 05-13-2011 02:46 AM
What Aftermarket Hood is this? ridenmystang Exterior 46 11-23-2010 11:07 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
