Post a Pic of Your Ram in its Spot
muddy12
Indiana
It’s a tight fit, and took several days of reorganizing, but I was finally able to put the truck back in the garage today.
There is just barely enough room to walk around both vehicles, and the truck just clears the door(thank goodness for the low profile xm antenna).
Jstmahoney
Northern California
2017 Ram 1500 5.7 Crew Cab 4x4
My ram is about an inch or two too long to cram in my garage. So it sits out. 662a57410a2b1894eb497cff002520e7.jpg
01Ram2500
My ram is about an inch or two too long to cram in my garage. So it sits out. Sent from my iPhone using Tapatalk
Yep and the Rams just keep getting longer. I think many of the Gen 5's will be sitting outside for this reason. That is why my 2014 is a regular cab. I had to have one that fit in the garage.
Gordinho80
Monroe, NJ
2012 1500 Big Horn
If I eliminated a 20" deep work bench I've set up on one side, I could squeeze it in. But I'd have to get out every time to pull the mirrors in. Its fine outside.
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
in it's place, right after I put the tails back on.
Curlyp
OH
Yea, mine is not so neat and tidy.
full
Curious, how much does the left like that run? Are you able to put your truck on it as well?
Roadhouse71
Kentucky
5.9L
Wow that’s insane doesn’t look that deep same thing happened to me in a Jeep was there for hours till help appeared lol
My front tire had wedged under a tree or root, couldn't move forward at all. Then my axles bottomed out and my tires weren't touching the ground. City boy stuck!
