Knocking when at low rpm
fxnytro17
2013 Ram 1500 Sport 4x4
2013 sport,
If I’m going over a hill with the engine in (for example) 6th gear, straining at a low rpm, it will start knocking badly. It doesn’t happen on the highway because the Rpms don’t get low enough. I’m talking like 1000-1200. Sounds like a diesel CAT ! Once I change the rpm or switch gears or whatever it stops.
No engine troubles as of now at 166xxx kms. (Knock on wood)
Anybody with the same issue?
OCDTech
Louisiana
2013 sport,
Sounds like the MDS, mine does something similar when i try to cruise at about 50 on level ground, feels like your in a manual transmission in 5th gear doing about 40. Lugging? Is this it. I just try to avoid doing 50, slower or faster is good.
fxnytro17
fxnytro17
It could be he mds. But it’s definitely a hard engine knock. It hasn’t happened on the flat, it’s always on an up slope. It’s like it should drop back but I’m not pushing the throttle that extra little bit to get it to change gears. This is always in auto as well. I’ll try using the gear selector and see. If it happens in that then I guess it’s not the mds.
Ramnewbie
Turn you're MDS off, then try it.
Never mind, I just realized you had a six speed, don't know if you can.
AZmtns
Southeast AZ
2012 Outdoorsman
My 2012 has a “flutter” at 1100-1200 rpm. When I turn on tow/haul it doesn’t do it. I figure it’s the MDS. It is definitely not a hard knock though.
Ramnewbie
My question is why, why are you running in 6th gear at that low of rpm? There is no point to it at all. That's deffinately not where you're torque or hp is at. Sounds more like a transmission issue not downshifting like it should.
fxnytro17
fxnytro17
Yes it is a 6 speed. It is the mds that I knocking. When going over a hill today(in auto) it ran to the low rpms again and I let it struggle over the hill instead of giving it more gas, it started knocking. So I knocked the shifter over to the gear selector and the knocking stopped instantly. With the gear selector mds turns off. The truck was in 5th gear not 6th.
I have the hemifever tune so the gear changes are all different from stock. And if you know how to drive your vehicle you can almost choose when to let it change gears by the way you use the throttle.
Ramnewbie
If you know how to drive you're vehicle why not let it shift so it don't knock.... Just sayin. I don't care what tune you have, intentionally letting it knock isn't doing it any good.
fxnytro17
fxnytro17
It’s not intentional, I’ve noticed it from time to time. Today when I done it, yes that was intentional just to figure out what was making the knocking now I know. Thanks
Ramnewbie
If you've got a hemi fever tune how come you're MDS is still working? I thought that was one of the first things accomplished by a tune was to shut off MDS.
RLJ10X
Southern Indiana
Are you sure you’re Tune is loaded?
I have a HF Tune. I don’t think it will let me chug around @ 1100 rpm.
fxnytro17
fxnytro17
Yes it loaded. He asked if I wanted mds turned off but I said no. I could always do that myself if I wanted.
If (for example) I can make it over a hill on the hwy doing around 110-120 kms/hr in 6th gear I let the truck do it. Why let it down shift, depending on driving mood I guess. The exhaust gives off this rumble and it saves a little gas.
The original part of this post was something that happened maybe once or twice. And I noticed it. It is not something I do on a regular basis. Yes going over a steep hill it backshifts and does it’s thing.
I’m done trying to explain this.
Thanks for the feedback guys. This forum is great, honestly.
fxnytro17
fxnytro17
I know compared to stock, and the original diablo 91 octane tune it’s not as bad. But yes if I use the throttle a certain way I can get it to go down to at least 1100 doing around 50kms/hr(I’m guessing) and I believe its in 5th gear.
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
Turn MDS off & solve your problem, you will get better gas mileage & performance with MDS off.
fxnytro17
fxnytro17
Didn’t think that was true but it’s worth a try. Gas mileage I mean.
Thanks
