2016 4x4 Lower Ball joints
Missouri2016
St. Louis
I've searched several threads to see if anyone has any long term feedback on which lower ball joints are holding up in their truck after replacement. Twenty different people, twenty different answers. Mopar only offers the entire lower at $450.00 each and i see mixed reviews on all including, Mevotech, Moog, Dorman. I'm kinda leaning towards Moog or AC Delco. With everything now being made in China, I guess its a roll of the dice.
BenchTest
Midwest
I'm going to venture a guess and say that's just going to be the sad reality on that subject. Just about every manufacturer is outsourcing their builds to try and be price competitive. I've always used MOOG for suspension components (for 30+ years) and have not been burned by them. I know others have had different outcomes. Like you said, twenty different answers from twenty different people. People have a lot of varying opinions on Dorman as well. I've used a BUNCH of their parts over the years successfully, but I can remember one or two duds in the mix. They make a TON of OEM and aftermarket parts, so with those numbers, sometimes they are going to miss the mark. Good luck on your quest, as I know it's almost brain damaging to try and sort through the options to make the best investment.
Jeepwalker
WI
2012 Reg Cab, 4x4
I guess if I was doing it, I'd probably go with (in no particular order):
1 TRW ...because they are greasable and have a weep-hole in the boot. A small attention to detail I didn't see in many of the other ball joints. Unless you want to stick with non-greasable joints.
2) AC Delco (Gold). ...only b/c I've have good luck with AC Delco parts. Don't look greaseable. But are you going to actually grease them? Or let any old shop shoot their cheap brand of grease in them (different greases are non-compatible and can ruin joint).
3) Mevotech TTX. Also greasable (optional) with a boot weephole.
All available on RockAuto
mrack
It really doesn’t make much difference, like you said they’re all made in China anyways. Your splitting hairs imo. Get whatever decent brand is cheapest off rockauto and call it a day.
Jeepwalker
WI
2012 Reg Cab, 4x4
Just because they're all made in ***, doesn't mean some aren't better than others. Different metallurgy ...greater attention to detail, slightly stronger build. AC Delco and I would assume others spot test with a lab (that's what they claim), therefore they would end up going with a company (you would 'think') which has consistently good quality. And they probably use the same supplier for as many other similar parts as well ...to swing better 'deals'. Large companies like AC Delco can't afford to be constantly switching companies when a certain company's quality control becomes 'less-good'.
We used to do a lot of work for Borg Warner ...for many years. I've been all through their local automotive OEM parts production facilities and talked to the plant manager and foreman/s in many meetings over the years. Essentially the way the contracts to the auto manufacturers are written they (the buyers) are pretty much 100% in the driver's seat. The suppliers get docked for quality control issues. And since the margins for auto parts is so small and they can't really afford to lose a big customer, there's every incentive in the world to keep quality control as high as possible. That's how it 'should' work.
If you buy greasable ball joints, be sure you do the greasing and use the same grease all the time. Buy a case of the same stuff, and don't let any other shops EVER grease them. That's my policy. Or just go greaseless.
Is your truck lifted? Do you need offset ball joints?
Missouri2016
Missouri2016
St. Louis
Appreciate all the feedback so far, and I think I', going to order (2) of the AC Delco Gold's and (2) of the Mevotech TTX. When I get them, I'll inspect all tolerances and make my decision on which one to use. I still have my Snap-On ball joint press from back in the day when I was an ASE tech. I've spent the last 35 years as a Journeyman Machinist, now Plant Superintendent. No, my truck is not lifted, bone stock. I do all my own work. The only time someone else touches it, is for tires. I've probably spent 20 hours in the last couple months reading posts and reviews as I am very picky. At 63, I'd rather spend $100 more on each joint just to do it ONE time. Had the last Ram(2003) 14 years.
Great truck.
Jeepwalker
WI
2012 Reg Cab, 4x4
I love RockAuto, but in my experience they don't always make it the easiest to return parts b/c you don't like them, or changed your mind (or that's been my experience). And you might have to pay shipping. Unless it's changed.
Missouri2016
Missouri2016
St. Louis
Got it, thanks.
chaosh1
Ill be installing the Carli when the time comes. only because im lifted on 35" tires
Missouri2016
Missouri2016
St. Louis
Got it, thanks.
Great truck.
I wound up stopping at my local auto parts(not a national chain) and bought (2) Moog lower ball joints. Surprisingly, they are made in USA. I installed them over the weekend and all went really smooth. Press worked great pushing them out, then news ones in. Only hiccup was when I was pulling the passenger side caliper off, pieces started coming out of the piston. Didn't realize they were composite. Installed a new AC Delco reman. caliper, and all good so far. The Moog joints have a recessed grease fitting that clears the boot on the axle. I added grease to them just to be sure before install.
