Bigskyroadglide
- Joined
- Nov 9, 2016
- Posts
- 1,347
- Reaction score
- 2,126
- Location
- Montana, except for work
- Ram Year
- 2014
- Engine
- Hemi 5.7, supercharged
I have it installed on my 16 laramie and I have not seen any ill affects from the install even in Montana winters. Granted it has not been super cold this year, only a couple below zero weeks. With the lowest being around -20 degrees.
I did not take out the active grill shutters on my 16, they work as designed and the truck comes up to heat as quickly as before. Also I left the factory thermostat installed as well. Only impact is lower Trans temp.
