I blame the Hanson Bros.Nope. Everyone in Canada appears to be blocked. We can only see it when we use a VPN with a US IP addres
For him to do it as a business it complicates things, I do it as just a joe schmo thing. Canadian shipping is no big deal for me, just sent another one today, in fact.
There's a few of my parts floating around Australia, several in Switzerland and a bunch in Canada
Does that kit benefit the trans or is it just a refresh kitJust got my Tracking # thanks !
Also got myself the Sonnax Zip Kit and the Improvised Racing High-Flow Engine & Transmission Oil Cooler Thermostat
All thats left will be my FRP re-tune for the tarns.
I have a buddy running it in his 750 rwhp turbo'd 392 4X4 and he thinks it's one of the reasons his 8HP70 is still alive.It's easier to just let you read their site,then explain it Khris.Does that kit benefit the trans or is it just a refresh kit
Zip Kit® - ZF8-ZIP
Sonnax Zip Kit ZF8-ZIP targets the root cause of multiple complaints by sealing the critical circuit pressure losses in the ZF8HP45/55/70 and Chrysler 8www.sonnax.com
Yea i don't know if i'd call it a performance upgrade.It cures leaking passages/seals etc,so the internal pressures stay up to par,helping to keep the transmission alive a little better when you start throwing more power at itI read their site but it pretty much says just as a refresh. Not really a “performance upgrade”.
The transmission cooler is in the top part of the A/C condensor ,so if you have issues with the cooler,you're also on the hook for an A/C evacute and rechargeI understand what Fiat Chrysler is doing here but they sure went about it odd. Like why not have a solenoid controlled by the ECU and a thermistor reading to open the passage, and have the passage larger for better flow.
Like they spent all this money to design and make the heater, and then use a budget thermostat setup to control the flow through it.
On my old F150 3.7 the standard transmission cooler is part of the radiator assembly and when the temps got too high the rad fans would increase speed. The auxiliary cooler was an additional fin and tube job that would mount infront of the rad so the fans increasing speed would still boost cooling for all fluids. There were no grille shutters, or a transmission pre heater.
Watch, with all these features my Ram will average the same fuel economy my 2014 Ford did lol
Good lord.The transmission cooler is in the top part of the A/C condensor ,so if you have issues with the cooler,you're also on the hook for an A/C evacute and recharge
Yeah that is the refrigerant we have in our trucks. Not cheap! And I think our AC sucks compared to the last gen. But I do live in AZ where it gets hot AF in the summer.Good lord.
Aren't these using the YF1234 refrigerant as well? Last I checked that was worth a few internal organs per lb
The 1234 refrigerent sucks in my opinion to G. My old 98 Regal with a bazillion miles on it,and 134,has never had any A/C work and will freeze you out on a hot day,in comparision,even my regular cab with 1234 doesn't get anywhere near as coldYeah that is the refrigerant we have in our trucks. Not cheap! And I think our AC sucks compared to the last gen. But I do live in AZ where it gets hot AF in the summer.
According to my A/C guy,1234 is also explosive under the right conditions.Yeah, the thing is R-1234YF isn't a global warming gas when released into the atmosphere, that's why it was developed. Read up on it. Per usual, such things don't work well and cost more.
Kind of like how FDA finally acknowledged "new" Sudafed doesn't work. I mean, what the hell good is something if it doesn't even meet the functional requirement of the product? Might as well put colored water in there and call it good.
It is, but there are a lot more explosive things in greater concentrations in a vehicle.According to my A/C guy,1234 is also explosive under the right conditions.
