Nice ! I got a 7" cluster from a 16 with 9k for $300Just bought a 7" cluster from a 16' for $270 with 19k on the odometer!!! Will be using this write up when I go to install it.
7" clusters are sensitive to amperage draw where as the 3.5 s wer not , you'll need oem bulbs or resistors to mimic the oem draw the cluster is looking for to make the message go out .
Wish I could be more detailed sir , I'm sure to have the same issue with my LED Spyder tails and my LED back up bulbs here soon .[emoji13]
I will have mine up for sale soon. found a rebel one for $150 locally
I'd try Novus , it's a plastic polish , I'd use the super fine grit .
Maybe try a very fine automotive wax ?
My guess is to go look at the module that's installed on the truck. Here's a picture of the same pn (2013 w/433Mhz) that I have from eBay...Hmmmm, interesting .
Is there anyway to figure out which ones you have with them installed with a tire ?
Build sheet ?
Sent from my SM-G900V using Tapatalk
Where's the module located on the vehicle Sir ?My guess is to go look at the module that's installed on the truck. Here's a picture of the same pn (2013 w/433Mhz) that I have from eBay...
Also, the Ram Body Builder site listed the same pn and frequency of tpms Sensors on their site/pdf
M² Mods - From my non Flammable S7!
Well here's a bit of interesting tpms info that might relate to the reason why the evic tpms compatibility changes around 2014/2015 (can't recall which year exactly).
When trying to order extra tpms sensors for my 2013 truck here's what I found..
Ref. Ram Body Builder site: Home | Dodge Body Builder's Guide
- 2013 tire & wheel info
http://www.rambodybuilder.com/2013/docs/intro/twlnwv.pdf
** My 2013 ram 1500 uses:
433(.92)Mhz sensors
PN: 56029398Ax (superceded by 68241067AB)
** 2013 Tpms module: 56029542Ax
(433.92 Mhz by Schrader Electronics)
Located near left front foglight on backside of bumper.
I received 4x of the correct Mopar PN sensors, but 3x are 433Mhz and 1x is 315Mhz. So it seems like there was a transition to 315Mhz during the 2014 M.Y.
Anyone care to confirm the Tpms sensors PN & frequency on their 2014-2016 trucks? I'm under the impression that the 2014/2015 & up Tpms module in the trucks are made by TRW vs Schrader (2013 & older).
