I had an oil leak that I diagnosed as a leaking oil cooler on my 2015 Ram 1500 3.6L engine with approx 160K miles. Pretty common issue from what I have read. I replaced the oil cooler assembly this past weekend and leak was gone. I used a bunch of shop rags to soak up as much oil as possible...
Hello need some help on trying to figure out what’s causing my transmission to drop to first gear transmission sounds right no grinding or any other noises. The first 15 min truck runs fine then when oil get normal temp it drops then I let it cool off for 5 min and it does it agin. I already...
Alright guys, the dreadful day has come. My Oil Filter Housing/Oil Cooler has failed @ 105K miles.
Here is a parts list I have whipped up. I plan on doing spark plugs, ignition coils, and valve cover gaskets in addition to upgrading to the Doorman Aluminum Filter housing.
Are there any parts...
