I apologize in advance for the noob questions.. I have a stock 2020 Ram 1500 Classic but I want the front to be level with the rear. At first, I thought about getting a leveling kit, but the more I read about those, the more I want to stay away from them. I think I will get some Bilstein 5100...
I have a 2018 Ram 2500 Limited 4x4 Mega Cab with factory air suspension in the rear. I would like to keep the factory air suspension. I want just enough lift to fit 35 12.50s and have zero rubbing and no trimming. Also maybe improve on the factory air suspension. I'm aware most likely I will...
I have a 2005 Ram 1500 ST 2X4 V6 Reg Cab with 17s. I just bought some 260/70/17 Wrangler At/s tires and (cuz I do everything backwards), I want to get some new wheels. I picked out the Fuel D574s 17x9 -12 offset, and found a set but the guy at the place I was buying said there would be a...
I know, this has probably been beaten to death here. I've looked at the FAQs, but still don't have a clear, reassuring answer.
Questions:
1 - Can i put a set of Longhorn or Laramie alloy wheels on an SLT?
Yes, both are 18". Yes, both have 8x6.5 lug pattern.
2 - Is there an offset...
Ok guys ive posted on here a few times and this is the last
2016 ram 2wd v6
Stock 17 wanting to go 20
https://www.carid.com/dub-wheels/push-black-9244572.html
DUB® - PUSH Gloss Black (20" x 8.5", +10 Offset, 5x108-139.7 Bolt Patterns, 72.6-90mm Hubs)
I was just gunna get the wheels and get...
I'm a bit surprised there isn't a thread to show off your aftermarket wheels. Maybe I missed it?
If not, how about posting your wheels/tires with the specs on what they are.
