wiring issue
  1. bassmatt
    2019 ram 3500 hemi backup cam inop - need help
    Hey all I have an inop backup cam with a break between connectors XY545A and XY543A. Diagnosed by ram dealer. This is a base model with the small screen, not the 9". Problem for me is I can't locate that myself by tracing the line, and the only diagram I've found so far doesn't have the...
  2. N
    WIN Module Replacement
    Ok, so I had a can of compressed air that was on the floor by the gas pedal spontaneously explode and it somehow went around the bottom part of the dash and totally obliterated my WIN Module. I have a 2011 1500 SLT 4.7, I have access to a WIN out of a 2014 Ram 1500. Obviously they changed things...
  3. Apauls
    PCM Communication problems
    Hey everyone first timer here not too sure how to navigate this site that well. My question: My 1996 ram 2500 Cummins doesn’t communicate with scan tools to diagnose anything. I even took it to a mechanic. I’d assume right off the bat that it’s my PCM or a wiring issue. I just installed a...
  4. R
    Installed new oem trailer brake controller, no luck
    I was all excited when I installed my own oem trailer brake controller and had the dealer enable it in the computer. Everything appears to present and working in the dash computer / menus. Problem is, the trailer brakes didn't work. Testing the plug at bumper, the brake pin gives constant...
  5. H
    2018 ram from quad lights to projector
    Okay so this is probably going to take me a long time to read but only cause i want to be thorough and hope someone can help me out. i just bought these lights that have switchbacks and halos both of which i can turn any color with an app. They are pretty much retro fits. Anyways they are...
  6. R
    Another electrical issue, 30a Megafuse blows, no trans lockup!
    Now working on several Dodge diesels. Problem of the moment is that the '94 2500 does not charge properly despite a new alternator and the trans does not lock-up properly. I've found that the relay controlling the alternator regulator switching has no power. It has no power as the 30a "Megafuse"...
  7. R
    Rear Tail Light Out
    Now I know everyone likely wants to tell me to check the bulb and the socket. I did both of those, but thanks for hoping for the simple solution. I did too. Truck: 2010 Ram Laramie 3500, 4x4, 6.7 Diesel What happned is this. The rear passenger tail light AND the passenger side light at my...
  8. B
    After market dual halo projector LED DRl headlight kit
    Good morming, looking for some help in wiring some aftermarket Auto Dynasty dual halo projector lights that I bought on Amazon for my sons truck. The simplest installation of the whole ordeal is the “plug and play” of the headlights. I plug them in and nothing. Hit the highs beams and one of...
  9. Vans28sk8
    2005 Ram 1500 Tail light mess
    I hope one of you guys can help me out. I purchased a 2005 1500 quad cab recently. The tail lights that are on there are older clear altezza’s that are fogged up and honestly just plain ugly. I ordered a new set of OEM replacements and went to put them in and to my surprise the left tail light...
  10. Big Red Truck
    NAME THAT WIRE COLOR?
    BIG RED TRUCK 1999 DODGE RAM 1500 SPORT QUAD CAB I bought this new in 99, special ordered with a camel interior. Well worn now 150,000 miles, thought I might trade her in for a new one. STICKER SHOCK !!! Not happening at those prices. So I'm doing a refurbishing. Putting her back together now...
  11. Drunken Hamster
    Intermittent bulb out light, right side brake light confirmed not working when it's on...
    Pretty simple, I've started getting lamp out warnings for my rear passenger brake light. The first time happened before I went and had the second muffler removed and a downturn put on, and I replaced the bulb [it WAS bad], but now it's happening again, and it's a little weird because the warning...
  12. L
    2007 1500 SLT Electrical Issues
    Hi Folks, Having a bunch of problems arising with instruments and sensors. I suspect the wiring harness/loom but can find no diagrams detailing routing and placement. The brake and abs trouble lights blink on/off on a fairly regular basis, the speedometer loses speed signal and drops to...
Joey93
