Devin A Mccollum
Hi everyone! My name is Devin and I have a 2004 ram 5.7. While I was riding down the road last October my main bearings went out and the crank seized on me. Completely shredded two piston heads, rods, everything, (got pictures if anyone wants to see)
So I took the engine out, had the block bored out .030 and replaced cylinder heads and did an entire rebuild. I replaced both cam and crank sensors, all mechanical components and got it all back together. Now when I go to start the truck it turns but won’t fire, I’ve tried resetting computer using battery cables, checked voltage at sensors. I have pressure in my fuel rail. I checked for voltage at the coil packs and I have voltage at the pack during crank(12v) however when I ground the connector to itself I lose voltage. I see voltage when I ground to battery off connector. I was told the crank sensor acts as the ground for the coil packs however all is testing good. Any idea as to why my truck isn’t letting voltage go through the packs?
