07 hemi need help!
MaryK
Lancaster SC
5.7L
I have an 07 dodge ram 1500 2wd 5.7L, I replaced throttle body since that was throwing a code, now I got a multiple misfire code changed spark plugs, coils, checked wires and fuses but has rough start with heavy blue smoke coming out exhaust then putting it into gear it shuts off automatically. Any suggestions, on a budget.. thank you!
jws123
nj
when you replaced the trottle body did you change the rubber gasket? the new throttle body could also be bad try swapping your old one back on see if it runs better does it have any new codes?
M
MaryK
Lancaster SC
5.7L
Was throwing all these codes (in picture) now it's just the p0300 (multiple cylinder received_217193851208017.jpegmisfire)
rzr6-4
nebraska
BLUE smoke or BLACK smoke? Blue is oil which is really really bad. Black could be soot from incomplete burn caused by your misfire.
jws123
nj
yea something is up with ur throttle body un hook battery for a while re install old one throttle body see what happens. Bad new parts are not uncommon at all as far as blue smoke check ur pcv valve clean it doesnt help that its running like **** so ignore the smoke for now.
M
MaryK
Lancaster SC
5.7L
Absolutely but I'm going to be replacing 8&6 fuel injector then go from there. Because yes it runs terribly and then stalls when putting into gear more less because the rpm isn't settling
LoneWolf3574
There is a procedure for programming/setting the new throttle body. I don't remember what it is, but I'm certain it is on YouTube.
M
MaryK
Lancaster SC
5.7L
New update guys, and yes I've done did the throttle body procedure. Anyways, took out all passenger side fuel injectors clean them up put them back in, truck managed to fire up and (be able to be put in drive and not stall) let it run a little then started back with stalling. Took the truck up the road a little and back home yesterday and today I finally got the engine reader home so I could read any codes that may have thrown and boy have a got A LOT what's your thoughts codes in next comment
M
MaryK
Lancaster SC
5.7L
Codes after driving yesterday and hooking it up this morning
P2111- Electronic Throttle Body Unable to close
P0642-Sensor Circuit Voltage 1 circuit low
P2122-Accelerator Pedal Position Sensor Low
P0222-Throttle position sensor 2 circuit low
P0122-TPS/APP Circuit Low
P0522- Engine Oil Pressure Sensor Low
U1120-Lost Wheel Distance Message
P0307-Cylinder 7 misfire
P0300- Multiple Cylinder Misfire
U0121-Lost Communication with Anti-Lock Brake Module
U1110-Lost Vehicle Speed Message
P0151-02 Sensor 2/1 Circuit Low
P0335-Crankshaft Position Sensor Circuit
P0108- Manifold Absolute Pressure Sensor Circuit High
jws123
nj
Did you wipe out all codes and then all this came back?
