100,000 Mile Maintenance Tips
rdlangston13
Katy, TX
I am new here on the Dodge Ram Forums and I have a 2006 Dodge Ram Hemi with 95,000 miles. I am going to spread out my 100,000 mile maintenance over the next three service intervals to keep the sticker shock of everything down, here is my to do list...
Spark Plugs
Engine Decarb
Throttle Body Cleaning
Shocks
Brake fluid flush
Power Steering fluid flush
Rear end oil change
Transmission Service
Cooling Hose out with flush
Any specific advice for any of the following items? I know I am way passed due on the plugs since they have a 30,000 mile interval and I have never changed mine. My truck is completely stock so there is not anything real special about it.
If you were going to break this list into 3 small lists equal in cost and time, what would those lists look like?
LS5DodgeRam
South Florida
4.7L v8
A lot of this stuff you can do yourself, its really simple... they have threads on here specifically for some, and that will help keep the cost way down
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
2019 (2003 Forgottens SOLD and 2014 SOLD)
Hemi 5.7 (392 Hemi) 86 Ford .308 HO Roller
List looks good. Should consider going into the front of the Motor and change the Timing Chain Tensioner as it is made of plastic and wears out and will give you another 100K Miles. Just something to Consider when doing the coolant Flush. The Timing Gasket is re-usable and you can leave the water pump attached to it and pull it all off. The Chain tensioner is 16 Bucks at rock-Auto and you can learn about the front end of the motor.
Mechanic rates are 100 bucks an hour in Canada so everything you do yourself pays for more parts and or any special tools you will need. Have Fun and Welcome to RF.
P.S. Careful on the brake fluid flush as the bleeder screws are known to break off, soak them good with Penetrator a day before you do the job, will save you from buying a new caliper or having to drill out for an oversized repair screw kit.
Danny
R
rdlangston13
Katy, TX
Thanks for the tips, I do plan on doing this all myself so that should save me a good amount right there. I will have to look into this timing chain tensioner
R
rdlangston13
Katy, TX
Thanks, and does anybody have any recommendations for shocks? It's just a stock 2wd but I don't want a real bouncy ride.
Sent from my iPhone
R
rdlangston13
Katy, TX
another quick question, i plan on decarbing with sea foam. where is the best place to introduce it? i was thinking the brake booster line if it will reach all the cylinders from there
Bscanlon64
Anyone have any further info on this tensioner? Very interested.
R
rdlangston13
Katy, TX
Is the brake booster hose the best option for introducing sea foam into the intake for a decarb???
2006 1500 Hemi
Sent from my iPhone
Ftank
