12 volt to keyed ignition
soapy
Northwest
6.4 hemi
My 2019 1500 has the 12 volt outlet on top of the dash linked to the key on. My 2022 power wagon is always on. I would like to convert the 2022 12 volt outlet to be activated with the key and not always hot. Is there a simple way to do this. I recall that you might be able to do it by switching a fuse in the fuse panel.
soapy
soapy
Northwest
6.4 hemi
I finally found the answer to switching the 12 volt oulet from constant on to Keyed on. In main fuse panel in engine bay fuse 90/91 you can move the fuse to change how your 12volt works. I like it keyed in case I forget to turn off radar detector or camera recorder.
Billq
Long island ny
Cummins 6.7
Just joined the forum
Thanks for the help
Made it so simply
Saved lots of time
Thanks
RamDiver
Marlborough, Ontario, Canada
Thanks for the help
Made it so simply
Saved lots of time
Thanks
Hey Billq, welcome.gif to Ram Forum.
There are endless gems like that to be found with a quick search here and if you ever require support for something irregular, there are many talented and skilled individuals here to assist. :cool:
