14 Ram 2500 Laramie Cab Light LED Swap
440hsp
6.7 cummins
I want to swap to the white leds in my cab lights to match my retrofitted headlights i built. Does anybody here know what type of bulb it is so i can order some. I was going to change out my map lights to brighter leds but seen on youtube videos that they have to change the whole upper panel. Any help would be appreciated.
Administrator
Cab lights? If your referring to the clearance lights, you may want to check your local laws regarding color, it may be mandated that they are amber in color. Although enforcement of the color of the lights may be similar to excessive window tinting, you won't get pulled over just for that.
If you have the LED interior lights, you can upgrade them this way: http://www.ramforum.com/f42/flickering_led_map_light_fixed-82756/
If you have conventional 194 bulbs, there are many plug and play LED "bulbs".
440hsp
440hsp
6.7 cummins
Thanks crash for that link
Shows me exactly what i need
snapper23
The amber lights are that color by federal and state mandate. If your state requires a yearly vehicle inspection then the truck will not pass .
Sent from my XT1585 using Tapatalk
Andrew09HEMI
You do NOT want to swap in white LED up there, trust me! Good friend did and got multiple tickets including impersonating LEO hahha. Cop got him hard. Now that's extreme but I wouldn't risk it for looks.
SIhemi
Pennslvanvia
I switched to white leds on my 16 2500. Haven't had an issue. If I'm not mistaken. You can run yellow and white. Just not any other color
ocwill1
Severn, MD
5.7 eTorque
I have amber on the outside 2, and white on the 3 inside and no issues whatsoever. They are 194 bulbs by the way. Here is a pic
440hsp
440hsp
6.7 cummins
Thanks guys for the responses. Ordered some bulbs from amazon. Slhemi and Ocwill1, what style of 194 led's did you order? How many led's per bulb.
Hootbro
U.S. Army Veteran
Delaware
2017 1500 Express 4x4
Pentastar 3.6L
Federal Law in addition to most state laws, mandate amber color lights in clearance light applications.
While others give the advice they have no problems, that does not eliminate the potential of where you live or if you cross into a locale that strictly enforces such things so keep that in mind.
Where I live and commute between Baltimore and Philadelphia, the local and state police regularly are looking for and come down hard on DOT compliance on heavy and large vehicles all the time.
https://www.law.cornell.edu/cfr/text/49/571.108
https://www.law.cornell.edu/cfr/text/49/393.17
440hsp
440hsp
6.7 cummins
I checked under my state laws and didn't see anything. I live on Houston Texas. But there's a possibility that I missed something.
ocwill1
Severn, MD
5.7 eTorque
mine all have 6 leds each
Hootbro
U.S. Army Veteran
Delaware
Pentastar 3.6L
TRANSPORTATION CODE CHAPTER 547. VEHICLE EQUIPMENT
Sec. 547.353.
COLOR REQUIREMENTS. (a) A clearance lamp, identification lamp, side marker lamp, or reflector mounted on the front, on the side near the front, or in the center of the vehicle must be or reflect amber.
(b) A clearance lamp, identification lamp, side marker lamp, or reflector mounted on the rear or the side near the rear of the vehicle must be or reflect red.
Acts 1995, 74th Leg., ch. 165, Sec. 1, eff. Sept. 1, 1995.
Ftank
