'15 Express 1500 Tailpipes
345Hemi
Pittsburgh, PA
Hey everyone, does anyone know the pipe Dia on the tailpipes? I know it is 2.25 off of the manifold to the "Y" then a single 3" to the muffler. Is it 2.25 again after the muffler? Also does anyone know if I could find aftermarket tailpipes in 2.5" with no resonators that aren't part of a cat-back system for $800+ ? Thank you!
Mineralram
I replaced my tips only with magnaflow ones they look better than the OEM ones
I used magnaflow 35117
Sent from my SM-G900W8 using Tapatalk
345Hemi
345Hemi
Pittsburgh, PA
Thanks mineralram, I'm looking to replace the whole tailpipes from the muffler back. I want to run a true dual system with 2.5" pipe by replacing the "Y" with an "X".
TRXHemi
Sugar Land, TX
I believe it's 2.5" out of the muffler. I just had the shop cut the resonators out when I had mine done. I added 5" black tips.
345Hemi
345Hemi
Pittsburgh, PA
Thanks, I will have to crawl under and measure them, if they are already 2.5 that will make this really easy. I will have the resonators cut out if I don't have to change the whole tailpipe! What did you do to your exhaust when you did it?
345Hemi
345Hemi
Pittsburgh, PA
Thanks Mineralram for the part # they are listed as 2.5" so assuming if my truck is the same I would have 2.5" tailpipes.
Mineralram
Yes they are 2.5 i cut my priginal ones off at the knuckle and rewelded so i can still use the knuckles
Kdog57
