1500 Would Not Move in Drive
Jwrigh12
Somewhere Notrh of the Equator
So this is way after the fact, and I havent had an issue since the incident... but am just now getting around to asking about it on here, and am wondering if anyone here has experienced this before.
The Truck - 2014 RAM 1500 Lonestar. 5.7 HEMI with the 8sp tranny.
Couple months ago Im out wheeling with my 5 year old, just exploring, and happened on a creek wash. It had rained a few days prior but wasnt too bad. All of a sudden the mostly dry ground turned into thick mud, and the wheels started spinning.
I put it in 4WD and was able to move a bit...but was pretty stuck. So I threw it into 4Low. I was able to get a bit more traction with this, but after a minute, felt that I was asking for too much speed out of the 4 Low, so tried to put it back into 4WD
This is where it gets interesting.
It started to switch but it refused to fully change. No big deal.. tried to put it back to 4 Lo. Wouldnt go back.
Tried Drive. Nothing.
4 Auto. Nada.
Each time the engine would rev, but no engagement at all.
Temps were fine. Nothing overheated.
Shut the truck off and waited for a min.
Went through the cycle again. Nothing.
Was getting an error message on the dash (dont remember the exact wording, but something like...) - Speed too Low for shift
Shut the truck off again. Spent a about 10 min googling things that made me very concerned. Fired it up again in one last attempt, and put it back into 4 Lo (the last option I was on before I lost power). Miraculously, the tranny engaged, and I was able to crawl out of the mud, and get home.
Once moving again (after clear of the treacherous mud...) It was able to shift from 4Lo to 4WD and back to 2WD. Ive never had an issue since.
So... DOES ANYONE HAVE ANY IDEA WHAT HAPPENED?!?! Any help would be great!
Daw14
Maybe your wheel speed sensor became covered in mud and could not send its signal.
ctwalton15
Kansas
I wonder if maybe like Daw said above A wheel speed sensor or possibly a ABS sensor. I know in my 09, occasionally Ill hit a large pot hole or something large at a decent speed and will cause my brake light, abs, tranny to shift, and service 4wd light to come on an sometimes it sets a code for me. All of this is a due to a wheel speed sensor I believe rear driver side.
Have you checked the trans fluid recently I do wonder if maybe driving it all this time I wonder if some is leaking or what not. Whenever I hear something like this I always would check the trans fluid first. I do have a leak on my truck. Mine is a 09 4th gen 5.7l with the 5 speed auto. I have had mine slip before so I added fluid due to it being low. I wonder if you are in the same boat. Might not be a bad idea to check either
NETim
Nebraska
5.7L
A few weeks ago, my truck simply would not move up and off the boat ramp. The engine would rev up but obviously it wasn't connected to the drive train.
I finally realized that the driver's side door wasn't completely closed.
Not related to your problem I know but dang, these trucks are getting too smart!
Jwrigh12
Jwrigh12
So I have the ZF 8sp transmission... which unfortunately is sealed. No dipstick to check it easily (although that is on the list of things todo...)
As far as the wheel speed sensor goes. That's one of the things that I was reading about. Only thig I couldn't figure out was... if the mud covered it, I highy doubt i would just randomly unvover it.
Daw14
Might have dripped off . I knew that question was coming , this is all internet diagnosis.
Jwrigh12
Jwrigh12
Yeah... too smart for my liking for sure. I enjoy some of the features, but sometimes, I just wanna live life on the bleeding edge. Door open, seatbelt off, flying down the neighborhood streets at a blazing 3mph. I mean is that really too much to ask?
Jwrigh12
Jwrigh12
For sure! Im not at all saying its outside the realm of possibility, and the truck has been fine ever since! Just wanted to come back to the brain trust and see if anyone has had anything similar/is aware of this happening.
ctwalton15
Kansas
Interesting, I didn't know those trannys were sealed. Thats kind of a ****** thing. I know mercedes and bmw like doing **** like that. We had essentially a "universal" dipstick you could stick through a bolt hole in the top of the trans to physically check the level but again thats odd I wonder who thought that was good idea to not put a dipstick on engine or transmissions. I don't think you mentioned that it set off a check engine light or not but with a decent scanner someone might be able to scan it and check all the modules to see if there is a trans/abs/speed code. That might not be a bad idea.
Klules
nl canada
1500 hemi
my truck would not move. seemed fine except it would not engage in drive or reverse. it was due to drivers side door open. i shut the door and realized the park break had engaged itself.
