ramffml
- Jul 12, 2019
- 2,833
- 5,222
- Location
- ramforum
- 2019
- hemi 5.7
Towing season is right around the corner. Still not happy with the temps I'm seeing in my truck unloaded, and also the pinging/knocking I get when temps get higher (never hear a ping when it's cold). I've already remove the active grill shutters but to be honest that just seems to lower my starting/normal temps by a few degrees but when the temps begin to climb it doesn't seem to help anymore at that point.
So I want to try a thermostat next. Can anyone recommend a good candidate? And @Wild one would you think a 180 is too cold for winters in Canada if I "never" see outside temps below -20C where I live?
I watched a video on how to replace it, looks much easier than I thought. Looks like they just clamped the hose down near the thermostat, pulled out two bolts, swapped and put the bolts back in. Some other questions I have:
- do these have a specific orientation (like is there a top/bottom to these thermostats)
- after the new one is in, do you put more antifreeze back in the rad or the overflow
- no issues with air getting into the system there?
- any other tips?
I don't do much wrenching as you can tell.
- any other tips?
