Younggunn98
Hey yall,
I'm sure this has been covered before but I'm racking my brain here. I have a 1994 1500 short bed single cab. I recently put a lift, 2001 3/4 ton axles and a transfer case from a 95 on it.. as well as 42 inch super swampers
It's all together after about 3 years of sitting. Some of which it sat without a transfer case or mount.
Now the transmission will not shift going forward.. it has reverse, 4wd works. It just has one gear. Speedo and tach work.
I tried swapping the speed sensor from my old busted transfer case. Same story. I'm told the ABS wires on the 01 rear axle can just be tied in with the wiring on the truck?
Any help would be appreciated thanks,
BGP
BGP
