Selecters75
- Jul 13, 2023
- 10
- 1
- 2014
- Hemi 5.7
Hello everyone. I'm having an issue with my 2014 RAM 1500, which I purchased about 2 months ago. A few days ago, while driving under normal conditions, without a load, at a regular speed for the road, I suddenly noticed that I had lost transmission. It was as if the gear had shifted from drive to neutral (although I obviously didn't do that). The gear shifter didn't move (it's not stuck either); it's just that when I pressed the accelerator, the engine's RPM didn't transfer to the wheels. I tried several times, both in reverse and forward, but it wouldn't move.
The next day, before taking it to the mechanic, who is an official dealer in my city, I tried again. Now it moved, but there was some noise when changing gears. The mechanic mentioned that the transmission fluid had an unpleasant odor. They said they would start by changing the fluid and checking if there are metal fragments in it.
Additional information: About a week ago, at the same mechanic, we did a service that included changing the engine oil. I asked them to check the transmission and differential oils, and they confirmed that the levels were okay and the fluids seemed to have been recently changed.
What do you think? What could have happened?
