1998 dodge ram 1500 5.9 stalling issue please help
Gunner reaves
V8 5.9
I got a 98 dodge ram 1500 it ran great this morning about a hour ago I tried to crank it and it cranked then started spuddering and then stalled out it did this multiple time like it was out of gas ( but its not ) any help of what it might be would be great thanks
MagSport
South Carolina
Will it not idle or can you give it gas to keep it running? If so most likely tps or iac.
ADudeOnSkis
Truckee, CA
318/5.2 Magnum
Ahhhh this again.... yeah most likely tps or iac, but could be any number of things. Check throttle position sensor, idle air control, crankshaft position sensor, camshaft position sensor, fuel pressure at the rail, spark plugs, plug wires (replace with 8.5mm), plug wire routing according to the tsb (ill try and find it and post it here).
Has your plenum been fixed? Any holes in your exhaust?
