2 or 2.5 levels?
DeputyDipShizz
Pennsylvania
I would go from the center of the wheel rather then the ground I case of tire pressure difference Or some other wierd variable. Gettin the truck on a flat pad helps you stay accurate as well
It would suck to measure 2 5/8" And only actually be 2 1/8" lol
I wouldn't reccomend having tire pressures that differ that greatly to begin with lol
***Disregard any and all typos as my large thumbs cannot fit the keyboard correctly***
11BPSMIKE
Quispamsis NB
I am thinking about going with the HBS 2" kit as I like a slight rake and I don't want the front to be higher than the rear when hauling anything. Also the shake issue should not be there or very minimal with the 2" kit.
PowerWagon2012
Schertz, TX
I have a zone 2.5" leveling kit sitting in my garage. Hoping to get around to installing it this weekend
badfish888
Va beach
2012 hemi express
not tryn to thread jack but does anyone know what the (vibration ) comes from in 4x4 and is there a diff between a 2" and 2.5" lol other than a 1/2"more vibration
quietpeen
2021 TRX
Hellcat
The vibration is caused by the increased angle in the cv joint
LB3711
Trumbull, CT
3.6L V6
it feels like a tire out of balance.
pd298
pd298
SE Oklahoma
The vibration is one of my concerns, but I dont use 4wd often enough to let it affect my decision. i will probably go with the 2.5.
badfish888
Va beach
2012 hemi express
now that makes sense, what doesnt is if the cv axle is spinning no matter what, y do you only get the vibration in 4x4?
iSlacker816
Kansas City, MO
5.9 (360ci) Magnum
This is what I did! Should look awesome with a 2"!
Rotzilla
colorado
6.7 CTD
I had 09 slt with a 2.5 inch daystar lift. After installation I had the 4wd shake.
Took it to the dealer and they rotated the front drive shaft 180 degrees and reinstalled it. Problem solved.
In my experience its the front drive shaft angle that is causing the problem, not the front axle CV's.
badfish888
Va beach
2012 hemi express
^ hmmmmmm so i wonder if it throws off the drive shaft balance?
Stangshcky12
Oshkosh, WI
5.9 Cummins
I wouldn't say off balance but it definitely changes the pitch angle
pd298
pd298
SE Oklahoma
Bump for pictures of 2.5 levels...Nobody has one?
blk11crew
i just put a 2.5 HBS level on mine. I'll try to get you a pick in the next day or so...
blk11crew
here you go. since this was taken, i added some bushwacker flares as well. no issues that i can feel in 4wd. but then again, i only use 4wd when i need it. i don't drive with it on all the time.
TNhemi12
That looks awesome Blk11crew, how hard was the install because the instructions look scary to me. Also, I hated the stock wheels when I bought mine (same as yours) but with the lift and gnarly tires they look pretty good for factory. Any rubbing issues running a 35" tire?
djnwc
I am thinking of doing a 2.5 as well...as i had put a 2.5 on my 06 and had no vibration....I used the top gunz custom one.....it just sat on top of the strut....so i guess going that route it shoud just be like a body lift right.....not really affecting the drive angles if you are just putting a spacer on the top of the strut the suspension angle really wont change right the body of the truck just lifts up.....I had no problems with it on my 06 and I was running the nitto mud grapplers 20x12.50x35....with a spacer.....still had no vibes.....so I think I will try them again for my 2011 level.....just some info for all to ingest.....
Stangshcky12
Oshkosh, WI
5.9 Cummins
It's not like a body lift as it pushes the spindle and axleshaft away from the frame causing the change of the angle
wwsowell
Central Arkansas
4.7L
I have a 2011 4x4 only use 4wd for winter weather so far, but i am looking at the HBS level kit as well. If i go that way should i have anything else done for the level other than the kit, new struts? or should i expect to have to change or have any problems with cv joints ect after so many miles? I just dont want to get it leveled and then spend money and time fixing things that go wrong because of the level! plus i am a little bit of a **** when it comes to crap i dont know a whole lot about!
